Question about Water Heaters
Hi Guy's, My gas bolier is leaking water whenever I switch the heating on. It's a baxi 0086 and I'm with Pheonix Gas. What should I do? Many thank's
  • 45 Answers
If it is the pipe leading in or out, you can repair it yourself with a torch and solder, after draining the pipes and turning off the gas.
If it is the tank itself, you will need to replace it. The tanks cannot be reasonably repaired, so replacement is your only option. Legally, you must call a certified gas fitter (or plumber with a gas ticket) to handle the removal and replacement.
I suggest shopping around yourself for a heater as prices vary widely, and plumbers generally charge more than a home improvement store like Lowe's or Home Depot. Have the heater on hand when the plumber arrives and it will be a very quick job.
Posted on Sep 08, 2009
Testimonial: "cheers dude It seems to have sorted itself out"
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
My bolier gas supply is going on and off while the water is on
if the flame keeps shutting on and off while running hot water. it is more likely to be a failing thermal coupler, here is what a coupler does- it is always in the pilot light flame which acts like a thermometer. it goes from flame to the gas control, if it is failing or has failed, it will shut the gas off. as a safety precaution.
Jun 07, 2012 | Water Heaters
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
My water heater keeps going off whenever the heat to the house is on.
check to see if the gas line coming into the house is big enough to support the water heater and the furnace at the same time. Call the gas co. and have them check their regulator for size and performance
Feb 21, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Water Heaters Logo
50 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
