Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox workcentre 385--"engine error"
Cannot print. Message on the display is engine error
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Need ubuntu linux ppd driver for workcentre 385
It doesn't look good. The following web-site called it a paperweight.
http://www.openprinting.org/printer/Xerox/Xerox-WorkCentre_385
If you have good windows drivers for this, then you might be able to share it off another system and print via Samba.
You'd be better off trading it, donating it, ebay-ing it, or keep it as a fax/ copy system.
Brother, on the other hand makes good multi-function printers and they have very good linux support for their printers. If you're casting around for a replacement, take a look at the MFC-4800.
Feb 20, 2010 | Xerox WorkCentre 385 Laser Printer
My Xerox Workcentre 385
Your probably got the copy key (readout) set at 10 copies. Try to go to the Xerox site and query for the instruction manual, this works most of the time. This will tell you how to negate the multiple copies
Jun 17, 2009 | Xerox WorkCentre 385 Laser Printer
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Xerox WorkCentre 24 error code 116-385
An internal shutdown occurred after an IDC (scripting language) processing error.
arrwup.gifInitial Action Power Off/On
arrwup.gif Procedure Reseat the ESS ROM and NVM PWBs. If the problem persists reload software ( GP 7).
If the problem persists, replace the ESS PWB ( PL 13.2).
Apr 24, 2008 | Office Equipment & Supplies
Using Xerox Workcentre 385 with Mac OS X 10.5
I went to the Xerox site and there is not a driver listed for a Mac platform for that product.
Wish I had a better answer for you.
Jan 26, 2008 | Xerox WorkCentre 385 Laser Printer
Engine failure notification
Yep. Most likely you could replace it for the price of repair
Nov 12, 2007 | Xerox WorkCentre 385 Laser Printer
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
111 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
