Question about Canon PIXMA MP830 All-In-One InkJet Printer
Can't stop memory lamp from flashing
The In/Use Memory lamp is flashing and I can hear a constant clicking noise. How do I clear this?
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
I turn on my canon mx310 and hear a constant clicking noise that lasts for 2 mintues, the alarm button flashes/blinks, and says "scanner error"... what could be causing that? and how can I fix this?
Issue: A grinding noise is heard from the device.
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
ALSO:
Make sure that the protective cover is removed from the FINE cartridge holder.
Jun 29, 2010 | Canon PIXMA MX310 All-In-One Printer
SONY KDS60A2000 will not turn on,flashes green light for a few seconds and then clicks off and red falsing light returns
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL5200 you can find it here:http://www.discount-merchant.com/Sony-Grand-Bare-Lamp-XL-5200-p/sony_xl-5200u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 30, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My Grand Wega KFE50A10 has a black screen. When started the power/standby light flashes green and the fan starts. After a period the same light starts flashing red in blocks of five. What does this...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2400 you can find it here:http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm?Click=48173 .Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Sound on the zoomlens and writing error # 45
To remove the error, follow the instruction.
1) Turn OFF the camera.
2) Remove the memory card from your camera.
3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera.
4) Turn on your camera.
This will clear the error. For noise install a fully charged battery or new battery in your camera.
Rating the solution in highly appreciated.. Good Luck
Mar 02, 2010 | Kodak EasyShare Z700 Digital Camera
My kingstone 2Gb memory is out of work
Sometimes OS does not detects the flash memory so it will not display anything in the your Computer....
Following are the Steps to check your OS configuration :---
Right Click on MyComputer Icon which on your Desktop and click on > properties
Click Hardware>>Device Manager>>Select Universal Serial Bus Controller >> clcik on Action from the menu bar >> click on scan for hardware changes..
if in the list of USB it shows some thing with "?" in yellow ..then theres driver problem in your OS
or else
Your Flash Memory Stick has been damaged ....
Dec 19, 2008 | Kingston flash memory card - 256 MB -...
Dlp tv problem
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Need drivers for Canon MP530 on Kubuntu I have an alarm light on and the in use/memory light keeps flashing. Also I hear a clicking noise constantly
The clicking noise is because your telephone line cord (from the wall) should be plugged into the "L:" port on the machine -- not the port with the icon of a phone next to it.
If you're not using a telephone cord, make sure your USB cord is not plugged into the telephone jack on the machine (it has been known to happen).
Don't know of any sources for Linux drivers.
Jun 12, 2008 | Canon PIXMA MP750 All-In-One InkJet...
In Use Memory is flashing and there is a clicking sound.
Yeah, I had the same problem and I had to pay $9.99 for the solution. :P I called Canon’s technical support for help even though I have an expired warrantee, so that’s why this little piece of information was so expensive. Oh well, at least I didn’t cry and I’m happy that it’s fixed. lol
So this is the problem, just like everyone keeps saying: THE USB CORD IS IN THE PHONE JACK AND THE FAX THINKS THAT THE PRINTER IS “ON HOOK.” The thing is, in the back of the printer you have a column of jacks, the one on top has an icon of a phone and the one on bottom has a picture of an “L” or laptop. TAKE YOUR USB CORD OUT OF EITHER ONE OF THOSE, NO MATTER WHICH ONE IT MAY BE. What you may not have figured out by now is that there is a THIRD jack that is not anywhere near those two. If you’re facing the front of the printer to the far right of the backside of the machine, there is this deep cavity that has your third, miracle jack in it. It’s even more to the right than the two jacks I described previously and its icon looks like a sideways, three-pronged cactus. Plug the square end of the USB cord into that jack, and the In Use/Memory light should stop blinking, and your printer can stop acting like car because the annoying, turn-signal clicking should stop as well. :)
You’re problem was probably the same as mine, when you moved your printer, you neglected to find your instructions manual (because you probably neglected to put that in a safe placed too lol) and you forgot which jack the USB cord went into.
Well, I hope my help was clear and that my $9.99 can go towards helping all those with this same problem and get use out of what seems like a waste of money. lol
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
