Question about Refrigerators
Fridge won't stay cold
At first we thought it was the seal because our fridge wouldn't stay closed, but when we fixed that problem, the fridge won't stay cold. we are not having a problem with the freezer. It is cold and still freezing.
  • 4,070 Answers
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 08, 2009
Left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Jan 24, 2015 | KitchenAid Refrigerators
Jenn-Air side by side refrigerator, Model JRSD2490. Not staying cold enough
Larger=colder. Make sure that 1) your magnetic strip around the fridge door is sealing well. Even a small leaking area could make it difficult to keep cold, especially in warmer areas. Also, make sure there is nothing obstructing the door from closing completely and sealing properly. I had this same issue where one of the door shelves was unlatched a little and the door would close but not seal. Beyond that could be motor or more likely compressor or coolant leak. Good luck.
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
Drain clogged on MCBR415S
Unless that fridge has an automatic defrosting cycle, NO water should be collecting at the drain area under normal circumstances. The only time that drain is needed is during defrosting (manual or auto).
Does the unit ever turn the cool cycle off or is the fridge always running (does the fridge ever stop humming)? If the fridge is always running, ice will build up in the fridge and it is either because the thermostat is broken or the door is not sealing properly allowing the cold air to escape. This can be due to something inside the fridge is preventing the door from closing properly, the door itself being not properly aligned with the fridge compartment, a broken door seal or a bend door or a bend fridge frame.
Ice can build up fast when a fridge is installed in an area with high humidity (like in Florida) and the door is opened frequently (like every 5 minutes to get a beer out, like during a house party).
If the fridge door seems to seal properly and the fridge seems to keep things cool, it might be enough to defrost the fridge to get it back in proper operating condition.
When loading the fridge, allow enough space between items, to permit the air to circulate.
Good luck :)
Jan 06, 2014 | Magic Chef Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
My Baumatic larder fridge won't go cold the fan and the compressor is working but the temp won't go below 16 degrees
Check to see if there is ice built up around the door preventing it from closing and sealing properly. This can happen if the door isn't closed all the way at times.
Jan 26, 2013 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Woods fridge will not stay cold
Maybe your frion is low, or maybe- believe it or not- the magnetic seal that keeps the door closed and sealed needs to be very clean and free of obstacles. eg. - Paper on a fridge or plastic inside the fridge. Good Luck
Jun 25, 2012 | Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Door won't stay closed
Make sure that the fridge is level. some times if it is not level the dor will not seal properly and will open by it's self. also check if the seals need replacing.
May 07, 2011 | Whirlpool Refrigerators
RS267LBBP fridge is not getting cold even though turned temp down
hello , can you hear the compressor kick on ? and if so have you checked the door seal ?
Apr 05, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
