Question about Zyxel P660HW-D1 Router
Can`t conect to the wifi
Hi! can`t conect to the wlan on zyxel p660hw t3 at home. cable is working normally
.the light- wlan on router is of. no reaction. maybe is hardware problem?
Cherrs for solution
    Master:
  • 441 Answers
Try resetting the router and then see if the WLAN will lit up.Maybe it just disabled on the router. have you tried accessing the router's setup page to see?
Posted on Sep 09, 2009
I have a problem in My Zyxel Router(P-660HW-t1 v2), WLAN light is not displaying and no manu of WLAN appears in Router Setup but sometimes it appear and after few minutes the router restarts and WLAN light...
Sounds like it may be a hardware fault. Have you tried resetting the router? I don't have the exact model but there's almost always a recessed button on the back which can be pressed with a paperclip or something similar. Holding this for a few seconds will reset the router settings to their factory defaults.
The default Zyxel password is usually 1234 or admin.
May 04, 2011 | Zyxel P660HW-D1 Router
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
WIFI problem
when you want to connect many things, the things you want to connect must have wireless lan, so that they can communicate with each other. if not no communication.because when wlan and Lan is being used together, it conflicts each other.
Aug 10, 2009 | Computers & Internet
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 upgrading the antenna
The internal address is 192.168.2.1. Default pass should be 1234. Hope this helps you.
PFC. Aaron Ramos
Feb 20, 2009 | Zyxel P660HW-D1 Router
Probleme wifi avec htc touch diamond
Salut,
Avec mon HTC Touch Cruise j'ai dû mettre la puissance du signal au maximum sur le HTC pour pouvoir naviguer, si je le mets sur moyen ou faible il se connecte mais pas possible de naviguer.
J'ai trouvé cette solution sur un forum italien et pour moi ca a marché.
Sep 23, 2008 | Zyxel P660HW-D1 Router
ZyXEL P660HW-61
while your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
May 08, 2008 | Zyxel P660HW-D1 Router
Zyxel p660HW-D1 firmware update
como abro los puerto para usar emule
Apr 25, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 drivers
Since you are referring to a router you can access the configuration using the web configuration you just need to type the router default ip address on your browser to access the configuration.
the default ip address is 192.168.1.1
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
http://dl01.zyxel.com/DownloadLibary_ShortName/P-660HW-D1/quick_start_guide/P-660HW-D1_1.pdf
Mar 02, 2008 | Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
558 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
