Question about Plumbing
Gen-x water pump pcx 40. stored 5 years, doesn't work
  • 523 Answers
Chances are the motor has failed on it. If this is a submersible pump they actually have a shelf-life. These pumps are typically filled with a water glycol solution with time this will slowly evaporate causing the motor to bind and fail.
I hope this may have assisted you,
Tom
Posted on Sep 25, 2009
I have honda forza 250. i have F problem
The Honda PCX / Honda Forza Forums • View topic - PGM-FI Problems.
hondapcx.org > Honda PCX > General
Jan 9, 2012 - 15 posts - ‎4 authors
I didn't go for the ride needed for the paint and have booked into my Honda ... big bore kit), 1996 Honda Nighthawk 250, 1987 Honda Spree, 2000 KTM 125SX, ... I hope I haven't got a dodgy one if I'm getting these problems. NSS300 Fuel Pump ...
Oct 9, 2014
Warranty Claim ...
Dec 10, 2013
Forza 300/A ...
Nov 27, 2013
Problem with oil.
Oct 2, 2012
More results from hondapcx.org
Jan 23, 2016 | Honda Motorcycles
I've got the Bosch AE 9.5 tankless water heater.
1) Cheapest and most reliable solution: Install tank-type electric water heater from local box store for $250. Get store coupons, offer 10% off store price. Repairs are made same day with generic off-the-shelf parts.
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
2) Install grundfo water pressure boosting pump.
http://www.ronhazelton.com/projects/how_to_increase_water_pressure_in_your_home
http://waterheatertimer.org/How-to-solder-pipes.html
3) Remove areators and low flow shower heads, Maintain unit as shown in product manual: Delime tankless unit yearly, Clean water filter monthly.
4) Call city and report low pressure and report issue as fire hazard, move to different apartment. Call apartment complex and ask why they didn't read flow requirements for tankless before installing tankless.
5) Call Bosch 866-330-2729 and complain that nobody read the flow requirement or tested local water flow before installing tankless.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 30, 2012 | Water Heaters
I have a PCX-5F POWER ACOUSTIK 5-Farad Digital Capacitor and after i turn the car off it stays on and sometimes when the keys not even in the ignition the cap stay on. why is it doing that?
It is a capacitor. Please read up on how capacitors work and it will explain itself.
The capacitor is holding a charge, just like it was designed to do.
Oct 01, 2012 | Power Acoustik Pcx-5F 5-Farad Digital...
2011 Honda PCX fork oil capacity
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $40 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
The Honda PCX Honda Forza SH Forums
Honda Pcx change front fork springs 20 UP PCX
2011 Honda PCX125 Scooter Service Manual $40
https://www.partsfish.com/page/oem-parts-for-honda
Honda PCX125 2011 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 31, 2012 | 2011 Honda PCX
My intex saltwater pump reads 88 and when I hit the arrows it continuously beeps without ever resetting to 0. I unplugged overnight and still doesn't work.
This thing is very sensitive. If you dont get the timing just right or in the right order that often happens.When it happens turn it off for a few seconds then try again. The book says hold the down button down for 5 seconds until you hear one beep, then up button for 5 seconds till you hear another beep. I find that 5 seconds sometimes isnt long enough and sometimes to long. Like I said, it is quite touchy. After two years still have it happen sometimes. P.S. Make sure the pump is running and water is flowing when you try it.
May 07, 2011 | Intex Automatic Salt Water System for ...
Cut generator into 230 volt water pump system
I would double check the wiring at water pump to verify the operating voltage and that the red,black and yellow are wired as you think and make sure you double check the wiring to the generator and verify the voltages of the unit with it running before you shut it off and make your final connections.Make sure youe your ground/neutrals are correct first the wire the hot leads.
Oct 24, 2009 | Plumbing
I have a Gen-x PCX 40 that sat as a back up for 5 years, I needed it, hooked it all up, plugged it in and nothing happened, the body of it got warm, no water movement. rickeppers@verizon.net The one I had...
Logically right. The older one - check it up for stucked
bearings or impeller. But first check the impeller, turn
by hand. To check the impeller is to open the pump end by taking off the bolts that hold it. If you can easily turn tthe impeller by hand, then the main problem is motor winding. It is either grounded or partially burned. It therefore needs rewinding. Send your e-mail for further assistance.
Sep 08, 2009 | Plumbing
Hayward eC-40 pump losing pressure very fast
A better way to clean the filter tubes in the EC40 is to remove the filter tube assembly and soak it in a 5 gallon paint pail that is filled with a solution of water and a 20% muriatic acid, available at hardware and home center stores. Be very careful handling the muriatic acid. Don't splash it around.
Mix it in a 1-to-1 ratio with water and soak the assembly for at least 8 hours. Keep the soaking pail out of the reach of kids and animals.
Remove the assembly, properly dispose of the acid mix and refill the pail with clean water. Soak again for 3 to 4 hours, then reassemble your filter.
Some pool guys say it isn't necessary to soak the tubes in clean water because the muriatic acid will not harm the pool water and will reduce the pH if it's too high. I've always soaked them to be safe.
This is a link to the Hayward manual that describes the process:
www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jun 25, 2009 | Hayward EC-40 DE Pool Filter with pump
Nano Will Charge on Laptop/ Will Not Sync & Will Not Connect to Itunes
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 19, 2008 | Apple iPod nano
Plumbing Logo
151 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
