Question about Maytag Neptune MAH5500B Front Load Washer
The small compartments that hold bleach and fabric softeners do not empty after the wash. ?I cannot figure out where a clog might be.
  • 3 more comments
  • cronda Sep 08, 2009
    mah5500bww
  • cronda Sep 09, 2009
    I sent you an email after this request with the model number mah5500bww. Did you receive that email?
    Let me know what you think I can do.
    Thanks.
    I dont see anything in response to my problem. I only see your request for model numbers. Am I missing soemthing?
  • cronda Sep 10, 2009
    All this aparent help posted on all these web sites. And I got nothing. I dont even get an acknowlegement. I wonder if I am missing somthing or if this is just another rude kid trying to pull a scam. this problem apears to be simple. Is there a referal? A diagram? Advice? another web site? Is there any integrity on the internet?
  • James Hilton
    James Hilton May 11, 2010
    I will need a complete model number, you will find it on the back of the console, toward the top.
Was this a scam to try to get me to buy repair advice?
Posted on Sep 09, 2009
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
I need a manual for Spectra TL3635 INOX washer
The manual doesn't appear to be available online, but you don't really need it.
Remove the drawer by pulling it out, and then lift and pull. Are you sure it isn't marked what goes where? My Whirlpool washer is marked in raised writing.
The detergent is one large compartment that is open at the back.
The bleach dispenser is usually in the middle and is small.
The fabric Softener is full depth, but has a system which siphons the softener out when water is added to it. In other words it is a reservoir that holds the fabric conditioner until needed.
With the drawer removed, turn the machine on to do a small wash. Water will come down on the section for detergent at the very beginning. towards the end of the first fill, another jet of water will come down to add bleach to the already filled machine. After the rinses, when it gets to final rinse, a jet of water will hit the Fabric Conditioner compartment. Get ready to insert the drawer if the water splashes out, or plug the front with a tea towel.
Aug 12, 2015 | Washing Machines
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
