If it is not reaching the cut off temp because
the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control. How to check everythinghttp://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
You turn the knob to say medium, the fridge appears to be working normally, the light goes on, the...
(More)
You turn the knob to say medium, the fridge appears to be working normally, the light goes on, the motor makes a noise, but the fridge does not get cold and the food goes off.
CPC240FF fridge wont work. The Freezer section works but the fridge wont get cold. I have changed...
(More)
CPC240FF fridge wont work. The Freezer section works but the fridge wont get cold. I have changed the control board but this hasn't fixed the problem. Any suggestions?
