Question about Plumbing
I have a Gen-x PCX 40 that sat as a back up for 5 years, I needed it, hooked it all up, plugged it in and nothing happened, the body of it got warm, no water movement. rickeppers@verizon.net The one I had just needed a cleaning it has a serial number 0964 the replacement one has a a number 5010365 I assume the longer number means it is a newer pump, right?
  • 832 Answers
Logically right. The older one - check it up for stucked
bearings or impeller. But first check the impeller, turn
by hand. To check the impeller is to open the pump end by taking off the bolts that hold it. If you can easily turn tthe impeller by hand, then the main problem is motor winding. It is either grounded or partially burned. It therefore needs rewinding. Send your e-mail for further assistance.
Posted on Oct 27, 2009
2013 Honda PCX 150 has vibration when cold
Hi, Anonymous and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
13. Worn out or broken universal joint on shaft drive models.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
The Honda PCX Honda Forza Forums
Honda PCX advice about racket from beltdrive
https://www.terapeak.com/worth/2013-2016-pcx150-pcx-150-honda-original-service-repair-manual-s32/111999082133
http://www.partsfish.com/page/oem-parts-for-honda
Honda PCX150i Owner Manual
May 13, 2014 | 2013 Honda PCX 150
My 1991 6 cyl automatic Toyota sat for a year with the battery disconnected. I hooked up the battery, turned the key and did not get the engine to even cough. I charged and then tried jumping the battery...
Tina-does the car turn over, that is, does the starter turn the engine over? If so, check to make sure the MaP sensor is plugged in-it is inline with the airfilter housing and the throttle body (the tube from the air filter to the engine) andi it has a large connector-make sure that is plugged in. Next 9assuming it turns over), get some starting fluid and disconnect that tube where it goes into the engine, spray a 5 second blast into the opening (open the throttle blade by twisting the blade by the throttle cable)-button it back up, try to start it-if it runs for a couple of seconds, you have spark and the issue is fuel related. If it does nothing, check for blown fuses for the ignition under the hood in the box by the driver side headlight, or the kick panel by the driver's feet-probably a bad fuse. Get back to here and let me know what you find out, we can go from there.
Apr 13, 2011 | Toyota Pickup Cars & Trucks
Gen-x water pump pcx 40. stored 5 years, doesn't work
Chances are the motor has failed on it. If this is a submersible pump they actually have a shelf-life. These pumps are typically filled with a water glycol solution with time this will slowly evaporate causing the motor to bind and fail.
I hope this may have assisted you,
Tom
Sep 08, 2009 | Plumbing
1999 saab 9-5 stalls without warning won't restart for 30-40 min.
Have you check the O2 sensors? How baout cleaning the MAF and Throttle body? Thermostat?
How does the temp gauge look whn it stalls?
Jun 25, 2009 | 1999 Saab 9-5
Buick Regal 3.8 dies while braking
Check to see if you have a lot of dirt in the throttle body. Clean the throttle blades out with brake cleaner or throttle body cleaner. You'll see alot of dirt come out. Keep spraying until it comes out fairly clear and wipe the throttle body out with a rag. If this doesn't do it, you may have a problem with the throttle position sensor (TPS). This sensor controls the idle after the car warms up and keeps it from dying when you brake or sit at idle.
Sep 07, 2008 | 1993 Buick Regal
Coolsat 7000 pvr
You could check for further info for this model through the following site:
http://forums.f2atv.com/
Oct 27, 2007 | Computers & Internet
Plumbing Logo
93 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
