Question about AcerPower 1000 (AP1000EA380M) PC Desktop
No power on Acer 1000ea380m
No power on Acer 1000ea380. My power adapter has a green light on but my Acer 1000-ea380m does not seem to be getting any power.
  • 674 Answers
Check the power adapter or charger first then the dc power connector... if its okay check the board ...
Posted on Sep 08, 2009
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
Acer Aspire 5920 will not power on. Power Cord, Charger, Adapter and Battery work fine. Adapter lights up green, no power light on computer keyboard or On/Off switch. CPU Fan is not working. Is there a...
There is a cmos/ rtc battery but that would have nothing to do with powering on your laptop. Most likely there is an issue in the circuit at the DC power jack. If the connection seems loose, or moving the plug at the point where it connects to the computer gives a glimmer of power then it is the jack. The DC jack is usually soldered to the motherboard and requires some knowledge to repair. If the jack is okay then there is a problem further up in the power circuit on the motherboard which means trouble.
This is what you power jack looks like and yours is not soldered, but has a 4 pin connector that plugs in to the motherboard. Much easier to replace than a soldered connection. Click HERE to see it.
P.S. Just because there is a green light on the adapter it doesn't mean power is being distributed to the connector tip. You may want to try a different adapter before spending money to have it diagnosed.
Apr 18, 2011 | Acer Aspire 5920-6727 Notebook
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
Acer 5570 not turning on. Adapter light is green. Battery light is also yellow. AC light is also green but the power is not there. Screen is blank
you can try to disconnect the battery then plug the power cable and turn it on.
if it doesn't work it will be a hardware power problem and you may get it to any repairing center.
thank you
Mar 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
AcerPower 1000-EA380M No Video
open the cover,try to find jumper "c-mos clear",probably is green,or red. put it on,then power on the machine abaut 3 -5 sec.then shut it down. then put the jumper in prevoius position and start macine normaly.on screen you have a note "c-mos clear,enter setup......",enter set up and chose auto configuration,save and exit and everything is ok.
Feb 04, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
