Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error message 6A00 with cannon Pixma MP600 printer
Get error message 6A00. Ink cartridge is all the way to the left and will not come to center. Looked for paper jams and cannot find any. Is this a common problem with this printer and is it fixable.
After changing the black ink cartridge, printer won't work - I have an 6A00 error - no lights are on where the 5 ink cartridges are - help!!
cartridge is not compatible, try putting old one and if work replace the new one.
if still not work then sensor or card is corrupted have to repair/replace them.
please check and post again here.
vote me if found helpfull.
Aug 01, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error
Error 6A00 checked under the print cartridge home position for any remnants of paper. There was no paper but there was a build up of ink on some clear plastic strips. Cleaned them off and it will resolved the problem. I hope this may work for some others also.
May 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
How do I solve error message 6A00 on canon printer?
Turn switched it off, open the lid and manually slid the cartridge-tray to the left. Use a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
Please let me know.
Sep 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
ERROR MESSAGE 6A00
dear troughton
I had this error (6A00) on a MP760 after a couple of months of not using it.
I switched it off, opened the lid and manually slid the cartridge-tray to the left.
Then I used a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
maybe you can succseesfull like me
post me in back
oke,thx
cropp
Mar 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
77 people viewed this question
old marine
old marine
