Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson D68 constant red light, checked through all known solutions, got 2 red flashing lights and now back to one
Both ink and paper light are flashing alternate and I cant get the printer to work epson d68
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Jan 11, 2010 | Epson Office Equipment & Supplies
Epson D68 2 red lights flashing, the green light is not on and the printer seems dead
Fix it with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Nov 07, 2009 | Epson Office Equipment & Supplies
Epson D68 red light on constantly, checked the ink cartridges, then had 2 red flashing lights now back to one
Remove and reinsert the cartridges - the cartridge lid may be open.
Also, the printer may need to be reset. From:
http://ribensan.free.fr/
Select the Epson resetter, Save, unzip and run.
Hope this helps.
Sep 08, 2009 | Epson Office Equipment & Supplies
Hi my R1800 has 2 flashing red lights (top) and no power light. What can i do? MAria
Hi.
It could be your ink tray has overflowed.
There is software http://www.ssclg.com/epsone.shtml which might help.
Install this program, set your printer model and the driver (Epson Stylus Photo R1800) when it starts up. Close the program, and it will minimize to the
tray on the taskbar - right click on the icon and goto "Protection Counter". Choose
"Reset Protection Counter". Choose "Yes" to the question about the waste ink pads,
then switch the printer off for 1 minute. This should cure the problem.
It might be worth a try
Jun 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Lost my insruction manual for the EPSON STYLUS D68
The documentation for your printer is located HERE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_33d06d08b28d1f14
Mar 10, 2009 | Office Equipment & Supplies
Epson stylus photo 950
It is not kinda solution but I can share my experience. I had it flashing all the time when I took out a cartidge.
Sep 24, 2008 | Epson Stylus Photo 950 InkJet Printer
I have an "Epson Stylus D68 Photo Edition". When turned on the Green light flashes on once and shuts off . Both Red lights lights flash alternatively and the carriage does not move. It's not out...
>turn it off
>check for any obstructions
>re-seat the cartridge
>turn it on
>if the lights flashes like it's Christmas, definitely a hardware issue.
check warranty status (Warranty starts from the Date Of Purchase) first before calling tech support for replacement.
Aug 25, 2008 | Office Equipment & Supplies
D68 epson printer,both red lights flashing alternately.
Fix with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Jul 14, 2008 | Televison & Video
2 red lights flashing??????????
when two red lights flash, come to a complete stop at the intersection..ok..now for a solution.
unplug printer from wall and computer..
wait 5 min.
plug into wall only
try the test page again..
check back here next..before plugging into computer, please..
check your computer's warranty here FREE
Feb 27, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
283 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
