Question about Garmin Nuvi 350 Car GPS Receiver
Nuvi 359 screen does not respond
Nuvi 35o screen does not respond
Garmin 265W After cleaning the screen with a duster--switched on, the screen will not respond to touch, I have updated software but cant use garmin as screen wont respond. cant hard reset again as screen...
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Aug 28, 2011 | Garmin Nuvi 265W GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Nuvi 660 touch screen not responding
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 20, 2010 | Garmin Nuvi 660 GPS Receiver
Touch screen locked and not responding. Nuvi 660
The touchscreen is intermittent and needs to be replaced. If your unit has a serial # that starts with "12P", "14V" or "143" then you have a style of screen that can fail without physical damage to the screen or glass. Please see this link:
- Jim
Apr 09, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
Touch screen on my nuvi 670 is no responding
The screen needs to be replaced. This is a common problem with the newer production run SHARP touchscreens. Please see this link for more info:
- Jim
Oct 19, 2009 | Garmin GPS
Garmin Nuvi 350 Car GPS Receiver Logo
20 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
