Question about AOC Computers & Internet
When monito turned on itsay no signal all
When monitor is turned on it says
no signal all conections are connected.
    Scholar:
  • 84 Answers
Something is loose. Either on the video card or the monitor. Either that or the video card is broken. This would not happen for any other reason
Posted on Sep 08, 2009
No signal going sleep
how old is your monitor? can you try to conect another monitor your pc has integrated videocard? does it turn on and beeps?, you should check the back pannel of your pc and try to conect it to onboard video first (if it has), if you get signal get into the bios and change video output from onboard to a external card. if this thing dont work, then vga cord may be damaged or the card is not installed right or not working.
Jun 05, 2013 | Fujitsu Siemens Computers & Internet
The monitor is registering no signal
No signal is not a problem with the monitoe unless the cabe is disconnected from either the PC or the monitor ends.
If the cables is securely attached at both ends it indicates the PC is not sending a video signal to the monitor.
Could be the PC hasn't booted up propperly.
Turn the PC off , wait 2 minutes and turn it back on.
Observe any lights on the front of the PC , especially disk activity light.. it should flicker .. alot.
If not then you have a PC issue not a monitor issue
Jan 21, 2011 | X2Gen MG19MY 19" LCD Monitor
Why the monito out sleep why
Pls check whether your cpu is properly booting because your monitor sleeps out because there is no signal detected coming in from the cpu try to connect your monitor to another cpu so that you can determine the proper operation of the monitor...
Jul 17, 2010 | HP W2007 LCD Monitor
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
My monito is not getting signal
if your monitor says no signal and goes to sleep when your pc is on then the first thing to check is if it's plugged into the correct socket. I've had people tell me yes to this question and when I see them all I do is plug the monitor into the right socket. They had an additional graphics card as well as the on board graphics output. If this is not the issue then the graphics output is probably shot, add new graphics card or replace motherboard.
Nov 04, 2009 | Gateway FPD1760 Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
EN9250 worked graet 20 minutes ago. Unpluged it to move computer- Plugged it right back in and now no signal. I have checked all connections and still no signal
Make sure the cable is plugged into the video in. Shut down the computer and unplug it. Unplug you monitor again and also check conections by removing the cable make sure no pins are bent on the monitor or the conection to the computer. Plug all back in. Turn the monitor on first and then the computer. I hope this helps. If not let me know I will need so more info. Good Luck.
Jan 15, 2009 | Computers & Internet
Monitor is connected to laptop jack and displays "no signal"
You have to activate the video out of the laptop.
Two ways to do this depending on how you want to use the monitor.
To use the monitor by itself laptops have shortcut keys.
Usually they involve using the Fn key and one of the F keys (Usually F3-F4-F5) KEy will either show two screens or say CRT-LCD
Pushing both keys at once will switch you to both screens, pushed again will just run the monito, Pushed again will return you to the laptop screen.
If you want to use the monitor as an extension of the monitor to be able to drag windos over to it then go to your display properties from the control panel and activate the monitor in the settings box. You'll have to click the monitor first then activate it as a extension and adjust the resolution here.
Fran
Oct 16, 2008 | Acer AL1916W 19" LCD Monitor
Benq FP222W
Try putting the resolution on 65hz if that dont work then try
different resolutions on the monitor. Right Click in a open area on your desk top and click properties and the click the monito tab to change the resolutions.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
212 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
