G'day, just trying to work out how to take the cpu heatsink off an amd ep-8k9a91 motherboard?
  • 674 Answers
What kind of your unit, PC of notebook?
of pc remove first the cpu fan the take it out the heatsink..
else notebook remove the body if nessesary then remove all screw to to take the heaksing w/ cpu fan.
Posted on Sep 08, 2009
Tip
How to Remove a AMD Processor
<p>Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.<br /> <p> <br /> <p>1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.<br /> <p><br /> <p>2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.<br /> <p><br /> <p>3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.<br /> <p><br /> <p>4. Pull the heatsink and fan on the motherboard and set it aside.<br /> <p><br /> <p>5. Lift the AMD processor motherboard and carefully remove it from the computer.<br />
on Jun 21, 2011 | Computers & Internet
Need a heatsink that will fit MSI 870-G45 Motherboard (Model # MS-7599). CPU is AMD Phenom II X4.
You can find heatsinks at the following link, you will need one that is compatible with
AM3 AMD 770 ATX AMD motherboards
If you look through each product, it will show you compatibility or you can filter search results.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Regards,
G33k
May 05, 2011 | AMD Computers & Internet
Amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A processor...so do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
Amd athlon xp 2400+ thoroughbred??
i am sure it will fit...because both are from same family and consists of same architecture only the bus speed of 2400+ is little bit higher than the other mentioned...
cheerrss..pls rate...
Jan 04, 2010 | EPoX EP-8KRA2+ Motherboard
Motherboard 8kra2+
This motherboard uses a style called Socket A. Socket A has 453 pins, so yes it will work with the processor you are wanting to use with this motherboard. Also, this is an AMD board, so getting an Intel CPU won't work, must get a AMD processor with this machine. Hope this helps!
Jan 01, 2010 | EPoX EP-8KRA2+ Motherboard
3 year old laptop computer with motherboard fan failure; can this be repaired?
the fan can be replaced, but it should be done by a tech as it requires experience in opening the case and installing the fan properly. don't try it yourself. the damage you can cause may be worse than the cost of a tech.
Nov 30, 2008 | Gateway Computers & Internet
Heatsink/fan mounting problem
I have never heard of using a certain cpu cooler that would void a warranty.if the cooler is for the cpu then use that 1 i/e the arctic
Oct 04, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
