Question about Gateway MD2614u Notebook
Gateway MD2614u Power button continually flashes and won't boot
I have had this laptop for about 5 months and I am currently deployed. I have my laptop plugged into a converter and suddenly the power button just kept flashing iv'e tried taking out the battery and using it with the power cord only and with both but nothing works. i can hear a sort of buzzing sound coming from the bottom of the pc everytime the lights flash. monitor is blank and the fan doesn't turn on. so far twice it has turned on after about 20 - 30min of letting it just flash, i could restart it but once i shut it down for the night it wouldn't work. it seems to be hit or miss? does anyone have a solution? is there anything i can try to fix it even if it means losing all my saved data ill try it, or am i out of luck? Thank You
  • 2 more comments
  • joseph_sobot Sep 08, 2009
    do you know what the cmos cell looks like on this model, im not very tech savy, still in the learning process. thank you
    when i take out the cmos cell should i leave the computer flashing or should i take the battery pack out and do it with the laptop off.
    i followed your instructions exactly and id didn't do anything to fix it. any more advice?
    are there steps to repair the chipset of the laptop or is there something i need to do adn replace it? I am deployed to iraq right now so i don't have all the resources like back in the states? If you could give me directions to do so please send them. Thank you
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue you are describing is usually due to faulty/loosely connected power connectors to the motherboard or hard disk. Check all the connectors inside the laptop. If the laptop still isn't starting and fan is also not moving then its a faulty hard disk drive. Also check the RAM dim slots.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 08, 2009
  • 4,281 Answers
First check in back side you find RAM .there open its cover mostly ram is fixed upon battery.
So refix RAM memory then check.
Still face same issue then open back side cover and find motherbord then pull cmos cell from motherbord for 10 minutes so all settings are reset to defaults.
Then check .
If still not power up the your battery need to change .
Let me know if you need more assistanse.
Thanks.
Push start button on gateway laptop md2614u
Hello Howard,
It has been my experience that the switches that are used on a laptop motherboard are a switch called a membrane switch. This type of switch is made of a elastic cover over a spring assembly. The problem with these switches is that the spring or elastic cover do weaken over use and time. The only cure is to replace the switch. On a motherboard it is less expensive to replace the machine unless you have the technical ability to replace the switch it's self. And that may not be all. Some switch assemblies may have more then 5 switches in the assembly. They can be very difficult to repair. If a electronics repair shop in your area reputes it's self as a component level repair then it might be worth a try. Be advised that there probably will be a check out fee that is paid up front. We hope that this helps you.
Nov 29, 2013 | Gateway MD2614u Notebook
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Gateway MD2614u, froze at start up when restart was attempted nothing appeared but a black screen. It will not restart. I have tried the battery/power reset, vacuum any dust and hooked up to another...
Actually this is a hard drive fault most likely, or a faulty had drive. If you don't have a recovery disk you are going to have to start the machine and try to do a recovery to boot repair. You can usually access this with F10 or F12, not really sure on a gateway.
Dec 29, 2010 | Gateway MD2614u Notebook
When I power up the computer the power button and keyboard lights will flash but nothing will turn on. What do I do?!?!?!
hello,,,,,,,,,,,,
This might be the problem of RAM ..........
Try to put the RAM into different slot....................
Jun 21, 2010 | Gateway MD2614u Notebook
Media read error check cable
Your computer tries to boot from various devices:
* CD-ROM
* disk-drive
* USB memory-stick
* 3.5" diskette
* network
in some order that has been configured (either at the factory, or by you, during BIOS SETUP).
So, if there is no media in the CD-ROM, no media in the diskette drive, no connected USB drive, then it will boot from either the network (if there is a network-cable that is connected to a "boot-server" system) or from the disk-drive.
So, is your disk-drive getting power?
Is the "data" cable between the motherboard and the disk-drive connected?
Is the disk-drive "dead" (not spinning) ?
Check your disk-drive.
You may need to purchase a new disk-drive, connect it, and reinstall Windows.
Apr 02, 2010 | Gateway MD2614u Notebook
Laptop will not boot. Lights come one then reboots, three times
try taking out the ram and putting it back in then if that doesnt work then try shutting down the comp , taking out the battery taking out the power supply and then pressing and holding the power button for 20 seconds , by doing both of these it resets on the info on the ram , or resets the bios to defalt settings
Feb 18, 2010 | Gateway MD2614u Notebook
Gateway MD2614u Notebook Logo
1,205 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
