Question about Epson Office Equipment & Supplies
Epson D68 red light on constantly, checked the ink cartridges, then had 2 red flashing lights now back to one
    President:
  • 3,278 Answers
Remove and reinsert the cartridges - the cartridge lid may be open.
Also, the printer may need to be reset. From:
http://ribensan.free.fr/
Select the Epson resetter, Save, unzip and run.
Hope this helps.
Posted on Sep 08, 2009
Epson d68 printer prints many blank columns
i think you need to clean it.if not take off the ink then put it again.( use an original ink, if not use a good ink)
Nov 21, 2013 | Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Both ink and paper light are flashing alternate and I cant get the printer to work epson d68
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Jan 11, 2010 | Epson Office Equipment & Supplies
Epson D68 2 red lights flashing, the green light is not on and the printer seems dead
Fix it with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Nov 07, 2009 | Epson Office Equipment & Supplies
Hi my R1800 has 2 flashing red lights (top) and no power light. What can i do? MAria
Hi.
It could be your ink tray has overflowed.
There is software http://www.ssclg.com/epsone.shtml which might help.
Install this program, set your printer model and the driver (Epson Stylus Photo R1800) when it starts up. Close the program, and it will minimize to the
tray on the taskbar - right click on the icon and goto "Protection Counter". Choose
"Reset Protection Counter". Choose "Yes" to the question about the waste ink pads,
then switch the printer off for 1 minute. This should cure the problem.
It might be worth a try
Jun 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Will not recognise all cartridges
some problems with compatible cartridges can be solved by taking all the ink out and powering the printer off then back on then put the ink back in, you might have to do this a few times also make sure no ink or dust has built up on the pins.
Sep 15, 2008 | Epson Stylus Photo R300 InkJet Printer
I have an "Epson Stylus D68 Photo Edition". When turned on the Green light flashes on once and shuts off . Both Red lights lights flash alternatively and the carriage does not move. It's not out...
>turn it off
>check for any obstructions
>re-seat the cartridge
>turn it on
>if the lights flashes like it's Christmas, definitely a hardware issue.
check warranty status (Warranty starts from the Date Of Purchase) first before calling tech support for replacement.
Aug 25, 2008 | Office Equipment & Supplies
D68 epson printer,both red lights flashing alternately.
Fix with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Jul 14, 2008 | Televison & Video
Epson 880
if red ink light is still on, check that the lid for the cartridge is fully seated
Dec 19, 2007 | Epson Stylus 880 InkJet Color Printer
452 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
