Question about Nintendo Wii Console
My wii accepts discs but they do not load - Nintendo Wii Console
  • ashlincoln Sep 08, 2009
    Thanks for your reply,not been dropped or knocked over as far as i know.It is about three years old,have tried cleaning kit but did not work,thanks.
  • Edward Jennejohn May 11, 2010
    how old is it? has it been knocked over , or dropped? do you keep your game disks clean? you could have a misaligned laser read head or a dirty one. you can probably get a head cleaning kit from a dealer. check the nintendo website.nintendousa.com, i think. good luck!
  • 148 Answers
Your wii is modchiped? or you are using normal mode with original discs? try to use a cleaning disc ...Good luck!!!
Posted on Sep 09, 2009
The Wii will not read my disc
Situation:
The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted.
If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Nov 15, 2012 | Nintendo Wii Console
My daughter crammed several discs in the wii at once. My wife removed 3 stacked out of it. Now it won't accept a disc past about 1/3 of the way in. Makes the sound like ejecting, but no others will come...
The loading/ejecting mechanism needs to be reset. It involves opening the Wii, and turning the gears on the side of the optical drive until the they are in the "Unloaded position". Turn the larger gear with the "belt" on it counter-clockwise until the plastic guide on the side is fully seated in the lower position. This should allow the Wii to take in a disc. If you don't have the know how to open and service your wii, post the problem on craigslist, and you should find someone willing to help you with your issue! Hope this helps!
Feb 26, 2011 | Nintendo Wii Console
Wii won't accept disc. console spits disc out
Try cleaning the disk and make sure your disk drive dosn't have any gunk in it then if that dosn't work try putting the disk in the other way.
May 08, 2010 | Nintendo Wii Console
Wii refuses to accept any disc
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
jarlagi10
Jan 08, 2010 | Nintendo Wii Console
My wii is not accepting any disc. I push the disc
I have just finished fixing a wii system that did the exact same thing. It had 2 pennies jammed into it. After i removed them it was perfect. I am a game sytem technician and a special type of screwdriver is required to open the unit. It can be purchased on ebay.Good Luck
Nov 23, 2009 | Nintendo Wii Console
Wii unable to accept/eject disc making buzzing sound
  • When the disks were put in/taken out the little plastic clips in side the wii may have broken off. Might be stuck near the motor. Gently shake while rotating the the wii with all the cords off with no game inside. listen for anything loose. If your lucky the piece will go to another part of the wii. Best thing is to find someone to take it apart to check.
Jul 14, 2009 | Nintendo Wii Console
My disc for Wii Fit will not load
If it is only your Wii Fit disc then you have a problem with your disc.
If your Wii won't accept any discs then you have an issue with your Wii DVD Drive.
You may have something jammed in there in which case you either need to send it to Nintendo for Warranty repair if you are still covered, or you would need to follow this disassembly guide: http://www.gaminggenerations.com/tutorials/wii/1-t870/
Hope this helps!
If you need more help msg me
Rate me please!
Jul 09, 2009 | Nintendo Wii Fit for Wii
Wii console won't accept a disk in. It sucks it
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Feb 28, 2009 | Nintendo Wii Console
Not accepting discs on wii
make sure the front of the disc is facing the right if it still doesnt work then try cleaning the disc and try again
Oct 13, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
69 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
