Question about Bissell 8910 ProHeat Clear View Upright Vacuum
8910 Bissell cleaner
Belts have been replaced and everything seems to be working however machine will not release any soap.
  • maxwellvern Dec 09, 2007
    bissell 8910, no water is being released although the suction works fine. Checked the filter, liones replaced pump all to no avail. any suggestions?
  • maxwellvern Dec 10, 2007
    The soap has no hope!!! Just got the water to spray as there was a plastic thing that went into a hole that was sitting on the bottom of the machine. Still there is no soap release.
    Sergeant:
    Champion:
  • 362 Answers
If you are getting power to the pump then it has to be something stopped up take the lines loose from the pump and see if you can blow through them if not its stopped up if you can you might not be getting power to the pump use a volt meter with it on and pluged in to see if you have power. at the wires to the pump and make sure you dont get an electrical shock be careful have the meter set on 110 V AC. try to blow through all the relevant lines to check for stoppage.
Posted on Dec 10, 2007
I have a ProHeat Bissell 8910 Series. Won't release or pick up
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
How to replace elt on bissell 8910
I have listed a link to the owners manual and a link to the belt you need. Hope it helps you!
Bissell 8910 User Guide (PDF)
Bissell 8910 Replacement Belts
Oct 31, 2009 | Bissell 8910 ProHeat Clear View Upright...
Change belt on proheat bissell 8910
I have added a link for the owners manual for your model and a link for the replacement belts you need.
Bissell Proheat 8910 Replacement Belt
Oct 30, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
