Question about LG VX8300 Cellular Phone
LG 3280 is roaming, charging double minutes. Tracfone no help.
LG 3280 is roaming, charging double minutes. Tracfone is NO help. Tried removing battery, adding zillions of codes, downloading stuff to it, and changing ph # even! I have spent hours on the phone with their so called Tech Support and have got no where. I had an old phone that roaming showed up on suddenly and they couldn't get it off after I spent 30 + hrs on the phone with them. So I ordered this phone in frustration and Whammy, same problem. PLease Help. Thanks
  • madattracfon Sep 19, 2009
    Also, I HAVE UNLOCKED THE CODE TOO! I have set it back to factory settings. I finally got it to quit charging double minutes in my area code, but as soon as I go 20 miles over to the next town it charges double minutes. There are Alltel/Nextel towers everywhere!!! It should not be charging double. I'm past frustrated...
I have 4000 minutes & 300 days on my tracfon. If I go BYOP to a smartphone, will those minutes & time convert over to the new phone?
I haven't had any problems coverting minutes from tracfone to tracfone. I have bought smart phones from tracfone and converted minutes to it. If you are trying to convert minutes to a smart phone, that is not tracfone, like Net 10, I'm not sure it will work. Your best bet is to call Tracfone yourself and ask them. They are very helpful.
Feb 19, 2015 | LG 500g TracFone
WHY SHOULD I CHOOSE HOME ONLY ON MY VALET TRACFONE? DO I NEED TO CHANGE THIS WITH TRAVEL? IS THERE A CATCH?
I believe this choice is to determine where most of calls/texts your will be made to. Choosing Home will designate your home area code as your most frequently called area (no roaming charges) while Travel will probably allow you to choose a different area code as your most frequently called area. When you call out of your chosen area code roaming charges apply. Example, if your current phone area code is 123 and you move to area code 321 you may want to change your Home or Travel designation depending on where most of calls are made to since you can't actually change your phone number.
As for your other question, you don't need wi-fi to text. It's like making a phone call, you simply choose message instead of dialing a number. Phone calls cost 1 unit, while text messages cost .30 units. (Units are the dollars you spend to buy minutes divided by the total number of minutes you receive) Hope that helps.
Oct 14, 2014 | Tracfone Wireless ZTE Valet
Optimus stav 3280
Have you thought about Universal Remotes? I bought a LG Harmony remote a year ago and never looked back. It plugs into your computer and after using the software you enter all the components of your home theatre, (including your 3280.) You can then use the one remote to control everything. Also some models have a charging base so you will not need to change batteries anymore.
Apr 14, 2014 | Audio Players & Recorders
Wont fully turn on
try a hard reset you can get the codes from here
http://unlockworldwide.com/unlocking_instructions/how-to-unlock-an-lg-unlocking-instructions/
May 29, 2013 | LG 800g TripMinutes Touch Screen tracfone...
My lg tracfone reads unregistered sim.It has always worked until I was not using it for about a wk.
Tracfone deletes SIM cards and the associated phone number from their registration database if the available airtime minutes goes to zero. Try buying minutes for the phone. (If you wait too long (~2 months), Tracfone may not be able to re-register the SIM card. In that case, you'll need a new SIM card.)
Do you remember when your minutes were due to expire? (Remember Tracfone doesn't do roll-overs of minutes.)
I hope this helps.
Mar 18, 2013 | LG 500g TracFone
How do I get to menu so I can download minutes to my tracfone
well there are two solutions to your problem you can take it to walmart and get a refund or you can call lg
Dec 30, 2012 | LG 500g TracFone
Setting My Phone's Time
Here is how to set the world time on your phone: First, press the left soft key--then, press #5--then, press #8.
Hope this helps ya--wicc--
also I have included a link to download your owners manual from--your phone is the 4th one down on the right in the list--just click manual and it will download
http://www.tracfone.com/phones.jsp?task=phones&subTask=allPhones
Mar 09, 2008 | Cell Phones
LG VX8300 Cellular Phone Logo
498 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
