Question about Dryers
Good morning. An underwire from my bra came out during drying and fell between the holes in the dryer drum. Now it makes an awful sound. SHould I take the back off the dryer to get to it?
  • 430 Answers
You will normally need to lift the top of the dryer, usually by removing screws mounted from the underside of the door area. Unplug the dryer first. Most dryers have a spring type clips along each side of the lid within 3-6" from the front. A putty knife or flat screw driver will help you pop the lid but you must be careful not to crack the enamel finish while wedge up to pop the lid
Posted on Sep 08, 2009
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
Making too much noise; not motor
hi there it could be a few things, but what i would do is take the back off and look at the spindle if you manually rotate the drum and the spindle is twisting its that! or as simple as it sounds i had the same issue but it was a underwire from a bra that had gone through the holes in the drum and wrapped all the way around the spindle! it was a pain to get out but the dryer up and running perfect now!
let me know how u get on
vic x
Mar 03, 2010 | Bosch Axxis WTA 3510 Electric Dryer
DRYER IS MAKING NOISES
A common broblem with dryers and washers alike is the underwire out of womens bras coming out and getting through one of the holes in the drum wich makes a horrible racket. Open the door and use a flashlight to look inside to see if you can see the underwire in one of the holes. They also get stuck in the front seal where the drum rides around this is another good place to look.
Jan 04, 2010 | Dryers
Bra underwire stuck in Bosch WAE22461AU
You can try using a very high strength magnet to bring the clip up to a hole in the tub so that you can then use a pair of fine long nose pliers to grasp it and reef the little blighter out!
Patience Does It !
Oct 24, 2009 | Washing Machines
Underwire from a bra is stuck behind drum
You wouldn't believe how common that is. If you can see part of the underwire, unplug the machine first! Then, try to pull it out through the holes in the rear of the drum with needle nose pliers or vise grips. I can't stress enough the need to unplug the dryer first. On certain brands the heater is right behind the rear panel and depending on certain circumstances there could be 120-240 volts to the heater even though it is not hot and the underwire could either be shorted already or will short when you try to pull it out.
Dec 19, 2008 | Dryers
I have a CTD40 Aquarius Dryer and an underwire from a bra has worked its way into the back of the drum through the dryer holes at the back of the drum. Is there an easy way into it to retrieve the item as...
take a pair of tweezers and a flashlight and turn the drum slowly around trying to see it and grab it with the tweezers to pull it out through one of the holes.
Jul 06, 2008 | Dryers
The underwire from my wifes bra has gone through a hole in the drum in our washer. its stuck itself under the drum and is making an awful noise. do u think it would be possible for me to remove myself? if...
when you do this the waranty will be voided.
it is not too hard to remove but it is time consuming. Did this many times before but you have to be patient and methodical.
not what you take of and you will have to split the outer drum.
Apr 21, 2008 | Washing Machines
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Thanks/Mike
Nov 06, 2007 | Washing Machines
Dryers Logo
67 people viewed this question
Top Dryers Experts
