Question about Toshiba Satellite P30 Notebook
Vertical lines in my laptop screen
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks! Thin vertical lines on Toshiba Satellite (no more than 2) for 4 months have come and gone in different locations - left half of screen- now a third is fluctuating and hasn't decided to become permanent yet - right in the center. Would really like to know cause. Have warranty but will have to buy new computer before having fixed as it is used every day.
  • edierosa Dec 09, 2007
    I disagree. The computer started with the lines at 1.5 years old. Also, though I use it every day, it could be termed "hardly used" (in terms of hours per day). The lid is closed just once a day and it has never left the house.
Sorry, but I find these sites difficult to figure out - I'm not a chat room person. I just wanted to thank dg9dotorg for the comments and whenever I finally find out the cause and get it repaired next year, I will advise what caused it. edierosa
Posted on Dec 09, 2007
    Scholar:
  • 151 Answers
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
  • 1 more comment
  • Chris Montano
    Chris Montano Dec 09, 2007
    Follow up. The cause to this is that the LCD liquids start to fail due age and regular use. Some remedy this problem by rubbing lightly the area where you see the vertical streaks, sometimes the flex cable that connects the lcd to the mother board gets ruined with age as well also resulting to the same bands of lines... The software I suggested can actually revive the pixels if the problem is just the liquid failing, if its a hardware issue like the flex cable, then theres nothing to do but back-up and replace...
  • Chris Montano
    Well you can go to your nearest repair center and have the flex cables changed, that should solve the streaks, it can't be solved either by software or manual rubbing... some call the flex cable ribbon wires... Although you used the unit for just 2 years, you still don't know the actual shelf life of the computer before you purchased it...
  • Chris Montano
    It's not mainly about how you used it, but the component life of the device... Parts like lcds have expiration life, and so does other wirings, I prefer connecting your computer to an external LCD so you can continue to use it ...
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
you could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
Jun 09, 2007 | Compaq Presario Laptop
Toshiba Satellite P30 Notebook Logo
493 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
