HAVE HAD THREE WASHING MACHINE REPAIR MEN WHO SAY THERE IS NOTHING WRONG WITH MY MACHINE BUT IT IS STILL NOT RINSING DESPITE LOWERING AMOUNT OF WASHING POWDER AND USING SODA CRYSTALS AND WASHING MACHINE CLEANER TO TRY TO CLEAR THE MACHINE
    President:
  • 1,776 Answers
I don't know if it has been considered, but I would look at a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the openings on the water inlet valve (especially the cold water side). Make sure they are clean of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 08, 2009
Why does my washing machine get stuck on rinse cycle?
Could be the set up, censer that controls the water flow is not doing its job. Call the number on the back costumer survise. or a repair men
Jul 08, 2015 | Kenmore Washing Machines
We have a Maytag 2000 front loader washing machine & dryer. Our problem is with the washing machine. The load was in the final stages of spin and I came into the area it is located and 1 was blinking. I...
This video will show you how to open your Maytag 2000 front loader washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 01, 2013 | Maytag Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Aquasmart - Machine keeps saying it is unbalanced.
this model is prone for the suspension rods to weaken and cause fault,fit new set of suspension rods
Nov 10, 2017 | Washing Machines
Siemens E14-16 Washing machine is not taking the softener when rinsing and posibly not rinsing completely. the dispenser drawer is clean and flows correctly when filled with water. I have checked the...
Same problem with same Siemens E14-16
Cleaned soap drawer inside out (no more black gunge) but still full of conditioner after full cycle and rinse despite 2 internal valves completely cleared and connected
What could be wrong ?
Feb 13, 2012 | Siemens Washing Machines
The dishes do not rinse properly--despite rinse
run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
My washing machine will not eptmy properley
You may be using too much detergent. Try cutting the amount by 1/3 and see what happens.
A
Sep 14, 2009 | Candy CNW136 Front Load Washer/Dryer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Lent in waterhose
Lint is nothing more than broken fibers in the fabric. To minimize lint, make sure you don't overload the machine. Loosely load items to the top row of holes in the tub. With a full oad, select the highest water level and use the proper amount of detergant. If you have a two piece agitator, verify the upper section turns one way like a ratchet. This action keeps the load circulating so the same items are not at the lower section of the agitator thoughout the wash and rinse cycles.
Apr 27, 2009 | Washing Machines
Washing doesnt seem clean or smelling clean
There are several things that can cause this problem.
Try this link there is plenty of information to be found here.
www.washerhelp.co.uk/diy-repair-help
Dec 03, 2008 | Washing Machines
Whites going gray improper water level?
I cant say nothing with out a visual check, but gona give you a tip, in the past one client complain the same to me, and was a leaky transmission getting grase in the tube, check that point..good luck
Aug 06, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
