Question about Craftsman Rear Mount Tiller
Not sure where to grease or change oil. - Craftsman Rear Mount Tiller
  • 69 Answers
Check the Sears website...they probably have manuals you can download.
Posted on Sep 09, 2009
What grease or oil do i need to lubricate the bearings and wobble plate on my Karcher pressure washer.
Use a Teflon based grease. Contact an auto parts store to buy it. The grease is usually colored blue.
Jul 16, 2016 | Karcher Garden
Can any garage do a oil change on a 2000 vw beetle? or do u have to use official vw parts?
Make sure they use compatible oil and oil filter. Go to a shop that has an ASE certified technician, and try to find a VW specialist if you can. Your performance car should be inspected by an experienced professional, not just a oil changing grease monkey.
Apr 22, 2012 | Volkswagen Cars & Trucks
Hello, my Hobart AE200 seeps oil from the front panel. How do I top it up? How often does the oil need replacing and with what type of oil? Thanks
It's not oil in the A200, it's #2 weight grease. Although when it gets old enough it can break down far enough to basically become oil (either that or someone put oil in it previously). There are a number of answers written on fixya.com explaining how to disassemble the transmission and change the grease. Fill with 36 ounces #2 grease. FYI : disassembling the transmission and changing the grease is a very messy task and one can VERY easily reassemble the transmission incorrectly, so consider bringing the mixer to Hobart to have the job done.
Aug 17, 2011 | Hobart A200 Stand Mixer
Does a 2000 lesabre need lubrication when changing oil?
there are some grease fitting on the rear of the car and there may be some on the front tie rod ends also .so yes they do need lubrication . alot of cars now a days do not have grease fitting for there suspenson parts . but when you have your oil change and you see a charge for lubrication this just maybe the way that company charges for there labor service for changing your oil .
Mar 04, 2011 | 2000 Buick LeSabre
My 06 cobalt has 55000 miles. ive had regular oil changes but im not sure what is done during a tune up. what parts are changed during a tuneup
please explain what you mean by tune up?? now to this old grease monkey that means fancy exhaust ,webber carb ,high lift cam and grind valves in ,polished ports ect ,so i assume you mean a service .Now this depends on the service as a service means different things to different mechanics ,now a dealer fitter will only change oil /plugs and filters as this is the most profitable for the dealer and the mechanic whos good with a pen for his bonus.But to an old fleet fitter like myself then a service is a lot more ,with a grease gun/oil can ,inspection and manual adjustment of rear brakes .Clean and grease the light bulbs ,in fact best part of a days work for one truck ,so please be more specific
Aug 27, 2010 | 2006 Chevrolet Cobalt
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Grease leaking from front end
Check the axle boot. When they rip or crack they will sling grease around.
Oct 29, 2009 | 2000 Chevrolet Blazer
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Have lost some oil out of it in moving, what oil
Hi. The oil you see used to be mixed into the grease base. It's time to change the grease in your mixer. Remove the silver band, Remove the top cover. Remove the transmission cover. Clean out the transmission, remove all grease and oil. Replace with Chevron FM ALC EP-2 grease. This grease is an edible food grade..
Remove the planetary gear, clean and re-grease. If this solution has assisted you, please rate it. ricardok45
Mar 15, 2009 | KitchenAid Food Mixers
2007 XL883 Oil Change
the sportster differs in that there are only 2 holes compared to the 3 on the softail. You drain the main oil via tube at the rear of the engine and the primary/trans with a bolt under the bike make sure you get the correct one as its close to the adjuster for the primary chain. you need 3qts for the motor with a new filter and 1qt for the primary/trans use the forumla+ or Spectro sporty heavy duty primary/trans in the primary and your choice in the motor. whilst your servicing it make sure all the motor mounts are tight and the fuel and oil lines are leak free and get the dielectric grease onto the fuse block and relays and adjust the primary chain
Nov 20, 2008 | 2002 Harley Davidson XL 883 R Sportster
Craftsman Rear Mount Tiller Logo
41 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
