Question about IBM ThinkPad T30 2366 Notebook
T30 power on password disable - IBM ThinkPad T30 2366 Notebook
  • 57 Answers
This is done in the BIOS advanced settings. To access the bios you must press the f key that flashs briefly as the computer boots up. the f key # varies from brand to brand. Watch the screen as the computer boots up, you should see it for just a few seconds. You may need the administrator password to access the bios settings if one was setup previously. If so you may have to contact the manufacturer for the procedure to reset/clear it.
Posted on Sep 09, 2009
I accidently removed the cmos battery of ibm thinkpad t30. After that error 0271: time and date setting appear then power on password show up. I failed to get into bios to change the time and date setting...
Removing the BIOS battery will not remove the BIOS password because the password is stored on an EEPROM chip. The password can be retrieved with difficulty, it requires you to build an EEPROM chip reader. For instructions to remove this password, please click on this link :-
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Dec 06, 2010 | IBM ThinkPad T30 Motherboard 91P7695 -...
I can't open bios of T30 ThinkPad IBM computer because I do not know bios passwords.I want to know way of open?
if you've forgotten the BIOS password, you'll have to check with IBM. Often, they have a way, usually a temp password like method that you can use to disable the BIOS password. for desktop systems, removing and reconnecting the coin-cell battery or a password reset jumper can be used, try to check the manual of your laptop if that applies to you as well.
Sep 16, 2010 | IBM ThinkPad T30 2366 Notebook
Cannot reset power on password( POP)
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net/t30.htm u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Sep 13, 2010 | IBM ThinkPad T30 2366 Notebook
Forgotten the BIOS password of IBM T30 Laptop
The BIOS password is configured from the BIOS setup and this password is stored on an EEPROM chip. There is no backdoor password available and IBM/Lenevo support says the motherboard needs to be replaced. Also removing the BIOS battery to discharge the BIOS and reset it to the default settings will not allow you to bypass this password. This also applies to the Power On Password and the Hard Disk Password.
There is a way to crack the password but you need electronic skills, electronic components and several programs plus a working computer to carry out this task.
For details on how to do this check this WEB site.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Aug 05, 2010 | IBM ThinkPad T30 2366 Notebook
BIOS password for IBM T30 Laptop
please you need to reset its bios. open the screws behind your laptop with keyboard icons to access your laptop cimos battery with care remove it for some time(3min), power on your laptop until it boots up. turn it off and put the battery back. the password will removed.
Jul 24, 2009 | IBM ThinkPad T30 2366 Notebook
Removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
Nov 04, 2008 | IBM ThinkPad T30 2366 Notebook
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
Power-on-Password Problem
press ctrl+alt+del 2 times and logon as administrator with blank password and then you can change or disable the password.
Apr 10, 2008 | IBM ThinkPad T30 2366 Notebook
Lost Master Harddrive Password
First chek in BIOS if exsist CHANGE HDD PASSWORD if not use download somwhere HIREN BOOT CD v8.2.Let me know if u got help;)
Oct 10, 2007 | IBM TravelStar 40GN 40 GB Hard Drive
IBM ThinkPad T30 2366 Notebook Logo
370 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
