Question about Microsoft Xbox 360 Console
3 rings of death
My console will not work . I get the 3 rings.
  • cpawlina Dec 09, 2007
    any fixes for the three ring of death
  • Anonymous Dec 10, 2007
    after getting the three rings of death i have contacted the microsoft helpline four times in the past month each time i call they reset my waiting time for someone to pick up the console for repair for another 4 to 5 days they have my phone number and have not bothered once to call me to say there is a problem this is well out of order worst part is u cant complain to nobody and nobody at microsoft gives a crap about there customers which they are treating like dirt.
Okay, i feel your problem, wrap the 360 in three towels while it is on. Wait for about 30 mins, take the towels off and then wait another 15. Works 40% of the time
Posted on Dec 11, 2007
  • 54 Answers
Hey cpawlina, and Guest,
I understand exactly how you guys feel, believe me.
The only fix I have ever seen for this, (which usually co-incides with an act of god), is to remove the hard drive, and turn on the system without it. Sometimes this will make the 360 work.
The reason why this sometimes will solve the issue, is because the read/write times between the dvd-rom and hard drive become way too laggish, it will cause this red-ring to occur.
But if that doesn't help, then there is no easy fix to it. It has to be sent to microsoft, and get it fixed. I apologize for no other advise. I hope this works, and if not, I hope the guys at microsoft can be of better service then they're known for.
SOURCE: XBOX 360 3 rings of death
i just got the 3 rings of death today and didnt get a warranty but i heard there was a 1 yr warranty on it
and if there isnt can anyone help me please ?
Posted on Aug 02, 2008
  • 72 Answers
SOURCE: 3 redlights aka ring of death
HI there, This is usually caused by the system over heating. What happens is the Graphics Processing unit, Central processing unit, Produce to much heat and warp the motherboard causing the Lead free solder to crack/break looking there connections.  If you're still under the 3-year warranty please contact microsoft for Repairs...  Things to keep in mind with the 360 console would be...  Console has to be kept in an open area with good air flow and not on carpet or in a place that will slow ventilation (inclosed entertainment centers).  Power supply also needs good air flow and vents should be kept clean of dust. I hope this helps and good luck
Posted on Mar 21, 2009
  • 94 Answers
SOURCE: Ring of Death/Red Ring
if you call ms they will still fix it for free
Posted on Apr 17, 2009
  • 2559 Answers
SOURCE: Ring of death on original Xbox
An indicator light that is flashing red indicates that there is an Electrically Erasable Programmable
Read Only Memory (EEPROM) error and that Xbox cannot start. EEPROM is a memory device that does not lose the information programmed to it when power is lost.
This is where items such as language setting, video modes, audio modes, and game region are stored.
Back to the top THINGS TO TRY
1. Remove all discs from the Xbox console.
2. Turn off the Xbox console and leave it off for thirty seconds.
3. avoid overheating and other problems.
Make sure the Xbox console is not located near a heat source.
Heat sources can include TVs, computers, monitors, and other electrical devices.
Make sure the vents are not blocked. There are vents on the left and right side,
and on the rear of the Xbox console. Make sure each vent has at least six inches
of clearance and space for air to circulate. If the Xbox is inside a cabinet, move it to see
if this prevents heat problems.
4. After the Xbox console is set, turn it back on and make surethat you see a steady green indicator light on the front.
5. If the console continues to flash a red light, the console may need repair.
Posted on Aug 02, 2009
  • 767 Answers
SOURCE: I tried the towel trick and the penny heat sink.
The towel and the penny trick are just that a trick.
The primary problem with your console and most others
is the G.P.U. has detached it self form the main board.
There are a few solid fixes that you can probably preform
yourself. First the G.P.U. will need to be reconnected ,easier
said then done . The x clamp hardware does not produce sufficient
or even compression vital to keeping the G.P.U.connected
so you will need a hardware up grade ie G.P.U. clamp ( C.C.A.)
Conformal Compression Assembly .This easily installable clamp
does one thing, it reconnects the G.P.U. and Keeps it connected.
and is available form www.allxboxrepair.
Posted on May 22, 2010
There are 3 flashing red rings on the console and it stopped working
This is the red ring of death and is usually caused when the unit overheats causing the solder to melt and bridge. Contact Microsoft to see if it is still under warranty.
Feb 15, 2010 | Microsoft Xbox Console
3 red rings
The three flashing red lights indicates general hardware failure. You have three year warranty for your device, you might as well have it replaced as no particular solution is out yet for the infamous red rings of death...
Dec 09, 2007 | Microsoft Xbox 360 Console
My xbox 360 freezes after being on for a couple of minutes. How do i stop this
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
Jan 05, 2010 | Microsoft Xbox 360 Console
3 red rings xbox 360
thats the Red Ring of Death send it in to xbox,call18004myxbox the red rings are a hard ware failure
Oct 15, 2009 | Microsoft Xbox 360 Console
I have 3 red lights on in my ring and i cant not open the console
for one thing when you have 3 red rings you cant open the console and your going to open the console to see what the problem is maybe something plugged out and wont work right try get a T-9 screw driver and maybe a T-8 one too and look at the x-clamps
Jul 29, 2009 | Microsoft Xbox 360 Console
My game plays for a min then frezers and gives me the 3 red rings
the red rings can be fixed in 2 different ways.
1) take all cords out except power corad and wrap it in thick DRY towl. then turn it on and let it overheat, this works 85-95% of the time.
2) send it in the console(you need the reciept)
and get it fixed/replaced.
NOTE:you can try both, if 1 doesnt work you can always do 2
Jul 12, 2009 | Microsoft Xbox 360 Console
Ring of death on xbox360
turn it in to xbox. they will fix it.
Dec 23, 2008 | Microsoft Xbox 360 Console
I got a ring on the on/off button on my xbox 360 console and no longer work, please advice
3 red lights in a ring....
Send it back to Microsoft for repair or replacement. They'll even send you a box to send it to them in. If you bought it within the lasy 3 years, it should still be under warranty, as Microsoft has extended the 1 year to 3 years for the "ring of death".
Call 1-800-4MY-XBOX for support, or go to
You'll have to register first.
Jul 23, 2008 | Video Game Consoles & Games
Xbox 360 problems
There isn't 3 Rings or there is? if there isn't (1 red ring) your harddrive is broke and you need to get a new one
Jun 28, 2008 | Microsoft Xbox 360 Console
How to make 3 red lights xbox360
easy just put something that covers the fans in the back and turn the xbox on and never turn it off and the red lights of death will appear.
Jul 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
