Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
I can't get the compressor to kick back on
I cleaned the filter, made sure the hose was on correctly and it just won't cool at all, the compressor won't kick on and I don't know what setting I should have it on on the front of the unit.
  • 396 Answers
It seems you have a defective compressor.
Posted on Sep 08, 2009
My ac fan works but the compressor won,t kick on
The fan on the condenser or air handler? Check the capacitor on the condenser. If you don't have a meter that does uf you can take the amp draws of the comp multiplied by 2650, divided by the voltage between com and herm on the cap. If cap is good be sure compressor is not off on thermal overload, cool with water hose, careful to not soak electrical. If not hot and cap good , try hard start kit. If still no compressor ,ohm compressor, com to start plus com to run should equal start to run on ohms. Hope this helps.
Apr 04, 2016 | Heating & Cooling
Compressor works, cooling fan does not, fridge and freezer are correct temp.
Where exactly is this fan located? Are you saying that if you spin it it does start to run? For how long? Tx, Petra
Jun 15, 2013 | Refrigerators
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Cooling fan won't come on when I turn on the AC
Your bigger problem is the compressor not kicking in. The cooling fan is not coming on because there is not enough high side pressure to turn the fan on. I would start by checking power to the compressor, fuses and relays would be inspect. Check to make sure there is the proper charge of refridegerant in the system.
Jul 29, 2012 | 1988 Chevrolet Cavalier Z24
Compressor keeps kickin on and off
Take a water hose and clean the outside condenser and then use the hose to cool off the compressor it is kicking out because of high head pressure/
Aug 14, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
I have ac unit which is only a year old. I just recently installed it, the fan is working but the ac is not cooling when set on cool. I cleaned the filter already, not sure what else i can do to fix this...
if you can here the compressor kick on (the fan will also be running) if the compressor is running and not cooling you could have a leak and it needs fixed and recharged
May 31, 2011 | Kenmore Heating & Cooling
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
Coleman rooftop a/c unit, fan runs, compressor come on/off
First of all, Shut off power to A/C unit. !! Next,You need to remove the filter /cover ceiling assy, and with a flashlight, look way up inside and you'll see the cooling fins etc, that look similar to the back of the AC on the roof. If they appear dusty/dirty, then they need to be cleaned. I use a shop vac with a couple of extra extensions to reach, and duct tape a pot scrubber brush (half round or round with nylon bristles) to the extension. Then start as high as you can get on the fins, and come straight down, kind of like combing the fins, but not pressing super ******* them. Move over, and down again, until you get them all, or at least as much as you can. (Thats basically the same as your return air at home) I use the nylon scrubber because the brush attachment with vacuum is usually softer bristles, and doesn't get in there as well. If yours does, great.Make sure you wash out your foam filter in a little dish soap & water before you put inside cover/filter back up. Now to the best part, The upper unit on the roof. You need to remove the plastic cover, by removing the 4 screws holding it on, or if it's dometic type, screws all around near the bottom of the cover, and lift it off. The front of the colemans have a lip that the cover is down over, so you may have to pull cover forward & up, then it should all lift up & off. Here's a spot to be real careful, and ready for wasps & bees. Very few, if any that I've done over the years, haven't had a bees or wasps nest under them, so if you can do it on a cloudy day, or at least be ready to move quick, and have a wasp blaster spray with you, it may be smart. Just don't forget your on a roof when you start moving !! Another thing to remember too, is that the roof can be very slippery when wet, or dew is on it, so watch out!! Be careful !! Now with cover off, look at the fins on back of the unit, and clean those the same way, or spray with a garden hose, and soft brush, and clean them up. Next, look at the opposite side of those coils/fins, where the fan blade is in front of it, and lightly wash it down as best as you can with the hose, spray nozzle, and a brush if possible. Remember when using brush, up & down as much as possible, to avoid bending the fins over. If you can't brush it , just spray it as good as you can, to clean it. Water should not enter trailer, unless maybe if you go overboard with spray, and pressure. If you have access to an air-line to use up on the roof, that's good to, but a lot of times, the water will wash it down better. This will more than likely cure your problem, if you get it cleaned out. At the RV resort where I work as a Technician, we usually have a flat rate of approx. $50 CDN. for me to do it for you. 95% of the time it cures the early cut-out of compressor, and people actually report it cools better than it has for a couple of seasons. It has to be clean to do it's job properly. When those areas are dirty, the upper unit (compressor etc) has to work so hard to cool, it overheats & cuts out, until compressor cools down a bit, then comes back on, until it heats up too much again, and kicks out again. That's why it doesn't do it as much in cooler times, because compressor doesn't get as hot. Your also shortening the life of your unit too.
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
