Question about Dell OptiPlex 760 MT Desktop Computer
System is getting Blue screen at the time of booting.
  • 49 Answers
The best option is to reinstall the operating system.
Posted on Sep 08, 2009
I get this blue screen when starting my dell latitude E5400 laptop. The system reboot fails regardless of the mode (i.e. Safe Mode).
Remove all USB attached devices like drives.
To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time.
Re-install Windows. Clean install works best, but all data will be lost.
Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 15, 2012 | Computers & Internet
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
I bought my wife this laptop (emachines G640)only a few weeks ago we've had a few issues at start up when it goes to the blue screen and the the screen where it says there was an issue and to start...
The stop error screen or bug check screen commonly called the blue screen of death (also known as a BSoD, bluescreen, or "blue screen of doom.
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Often, if you're lucky, the problem will resolve itself with a simple reboot and you may never have to worry about it again. More typically though, the BSOD is a harbinger of trouble and you may find yourself faced with another and another until you throw up your hands in frustration... but all is not lost.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This is if you are able to boot into safe mode (Press and hold the F8 key during boot up). This will ensure that all driver bugs are fixed and that all hardware has the correct driver. If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name. There is a neat program on the net that can fix this problem, it's called DriverFinder, you can get it here.
If this doesn't work or you can't think or find the corrupt driver you could use System Restore (If it is enabled) to go back to a time where you didn't get the error. To use the system restore utility, go to 'start/all programs/accessories/system tools/system restore.
Sometimes though the blue Screen of death can be caused by faulty or loose rame cards. Check that your RAM modules are inserted correctly and arn't clogged with dust.
Feb 02, 2011 | Computers & Internet
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Aug 20, 2010 | Dell Inspiron 1525 Notebook
Blue screen was appearing while booting the system
This is a driver issue, try this. Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 04, 2010 | Dell Latitude D600 Notebook
Computer will not start, it turns on then a blue screen comes up and restarts
When you turn on your laptop keep pressing the F8 key to get to a boot menu, then choose safe mode and see if you can get into windows that way. If you can get into windows then go into the system tools folder and choose system restore and choose a date the last time you didn't get the blue screen of death and let the sysem reboot and see if you can get back into windows.
If you can't get into safe mode and your still getting the blue screen of death, then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your cds if you have them.
Jun 29, 2009 | Computers & Internet
Won't boot
Here is the cause, and I think you will have to re-install the operating system. Not knowing your machine model number, I have no idea if the operating system recovery is imbedded in the hard drive or not.
http://www.geekswhoknow.com/articles/stop-0x00000024-0x0000024-0x24-ntfs-file-sys-error-code.htm
If you receive a blue Dell line across the top of the screen during power up, press F11 to see if you can get into the recovery mode. If so, just follow the instructions.
Mar 18, 2009 | Computers & Internet
Blue screen
Blue screens on a system with an activated copy of Windows are usually the result of hardware changes. I would take out or unplug everything except the boot drive. If it boots OK now, put things back in one at a time and reboot. I know it is time consuming, but if you do 2 or more at a time you don't know which one is causing the problem. I would take pictures of the insides the way they are now so there won;t be any confusion. Pictures are easy to delete, but hard to create if you don't have one of the connection you are unsure of two or three days from now.
Oct 29, 2017 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Nov 30, 2007 | IBM ThinkPad R51 Notebook
Dell OptiPlex 760 MT Desktop Computer   Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
