Question about Dayton 511 Utility Heater
Replacement parts need to buy flame sensor
    Problem Solver:
  • 19 Answers
Dayton was made by Desa. desaint.com has parts or run search for reddy heater parts the photo cell should be the same.
Posted on Mar 02, 2008
I have a suburban RV furnace DD17DSI. I have replaced all major parts. Furnace will complete 3 cycles each time ignites flame then flame goes out. any ideas?
check flame sensor ignitor assembly if ok check burner tube see if flame touching ignitor flame sensor assembly also check gas pressure if all ok control board or bad ground
May 01, 2018 | RVs
Pool heater comes on and gas enters unit for about 5 seconds and then the gas shuts off. natural gas
This could be the flame sensor. If you can look into the firing chamber there should be a steel rod about 5" long that dangles into the gas fire jets. Turn off the unit. If you take the fire sensor out and gently rub it with steel wool and replace it, it may start working again. If it does, great, but order a new fire sensor and replace the old one when it comes in. They are very cheap.
May 05, 2017 | Pool & Spa
For a RUUD Silhouette II, what is the part number for the flame sensor?
You will need the make and serial of you appliance from that you can get the part you need from a stockiest
Dec 28, 2015 | Heating & Cooling
Why does my bosch 25e ingnite then blows out repeatedly and occasionally stays on if i turn tap on and off and on for abit.
Does the unit have a flame sensor? Check manual. Flame sensors get corroded and need cleaned or replaced. I have had success cleaning them but when you can buy a new flame sensor
Apr 25, 2014 | Bosch Water Heaters
Sta-Rite Propane heater ignites flame and within 2 seconds shuts down.
With the limited information provided above, I would say that it is your flame rectifier (flame sensor).
If the heater ignites, and the flame sensor is bad, it will go out right away as a safety precaution.
Below is the parts/troubleshooting manual for this heater. You can find the part number for your flame sensor, and replace it.
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Jan 21, 2011 | Sta Rite Sr400na Max E Therm Pool & Spa...
MAYTAG GAS DRYER MODEL SDG305DAWW. THE IGNIGHTER GLOWS BUT DO NOT REVEIVE A FLAME
Your igniter is working fine. The problem is the flame sensor needs to be replaced. The flame sensor is a safety feature. If it doesn't detect heat from the igniter it prevents the gas from flowing. A new flame sensor will cost about 30 - 35 dollars. You can buy on online here
Jun 23, 2010 | Dryers
Kenmore gas dryer #110.97282100 won't heat. what part do i need?
Your easiest (cheapest) starting point is with the thermistor (flame sensor).
You can easily check that it is in direct contact with the pilot... and at the same time - check the ignitor is sparking
1. Check for ignition - if not igniting - replace ignitor.
2. Check/clean Flame sensor - if pilot is lit - replace the sensor.
3. If voltage at the gas valve checks out (from flame sensor) - gas valve should be replaced.
CLICK HERE to see the available parts if one of them is not working properly.
Feb 28, 2010 | Kenmore Dryers
Goodman Dependable 92, ignitor and fan comes on for 3 seconds, furnance does not turn on. Goes through 3-4 cycles, then shuts down furnance. If it is the flame sensor, where can one buy parts?
Do the burners come on? If so then yes it probably is the flame sensor if not then there is another issue not the flame sensor. The flame sensor could just be dirty take the flame sensor out and clean it with a piece of emery cloth or lite sand paper and put it back in and this should get the burners to stay on.
Feb 05, 2010 | Goodman GMS90703BXA Heater
I have a Whirpool gas range. Everytimme I hit bake and start the oven starts to heat up. After about 20 seconds it shuts off. I got error code E303 so I replaced the oven temp sensor but that didnt fix the...
The flame sensor is bad. Go to repair clinic. com and put in the model and it will pullup the parts for your oven. Buy the flame sensor. It has to 'see' the gas flame to remain open from the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 06, 2009 | Ovens
The pilot light will not stay light
The flame sensor is not sensing flame. If it is a thermocouple sensor, they can be purchased for 6 bucks and replaced in 15 min.
Some units have a different type of flame sensor and are a part of the ignitor assembly. In that case, the ignitor assembly would have to be replaced. Those usually run 20 to 60 bucks.
There is a remote possibility that the sensor and pilot flame shroud need to be cleaned, due to rust and other corrosion preventing the flame from properly contacting the sensor. You can try cleaning that first, but chances are you will simply have to replace the sensor.
Oct 11, 2009 | Water Heaters
Dayton 511 Utility Heater Logo
101 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
