Question about HTC Touch HD Smartphone
I have installed Garmin Mobile XT v5.0 on my HTC Touch HD. I followed the process described on the net but when I try to use any of the functions, like Address it tells me "Detailed maps are required for this operation". I have already loaded all the maps via mapsource onto my device? I used Keygen to generate a device unlock code and copied that to the sw.unl file on my storage card.
I want to unlock htc touch hd
You can Unlock it simple by using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-1.pngTheunlockarena and Unlock it...You can follow the instructions below and Enter the code
HTC Touch HD Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Touch HD mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Touch HD mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Touch HD with a Not ACCEPTED SIM Card.
2. If your HTC Touch HD asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch HD will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch HD is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Touch HD is locked to.
Jul 29, 2011 | HTC Touch HD Smartphone
Hello there, I bought a china brand gps with built in garmin mobile xt, how do install road maps. I'm from the philippines by the way.. Thanks for helping me...
Welcome to FixYa!
To update your map, go to https://my.garmin.com/maps/chooseDeviceType.htm? Choose your device type. I believe Garmin Mobile XT is under the "Phone Devices".
It will ask you to install the Garmin Communicator Plugin, install it and follow the instructions. You may need to connect your GPS to the computer during this process.
I'm not quite sure if a road map for Philippines is available though.
Thank you for using FixYa. Have a great day. Jas247
Note: CDRKing also released a less expensive GPS tailored for Philippines.
May 13, 2011 | Garmin Mobile XT GPS Receiver
Htc touch hd not recognised and will not install to pc. running on windows xp
You need to first install activesync, this will then install the USB drivers for XP. Once this is done, then connect your device and your PC should see your mobile.
If you still having problems, trying removing the unknown device from Device Manager.
1. Click start 2. Right click on My Computer 3. Go to Properties 4. Go to Device Manager 5. Check for a yellow triangle with an exclamation mark 6. Remove this device 7. Follow instructions above
Mar 02, 2011 | HTC Touch HD Smartphone
Flv videos just dont play in my phone...what all video formats does htc touch hd support?
Good day,
I read the Touch HD's spec sheet and it looks like it can only play the following formats:
MP4, H.264 and H.263
It also has a YouTube client.
Hope this helps!
Kind regards
Dec 02, 2010 | HTC Touch HD Smartphone
HTC TOUCH HD CONNECTIVITY PROBLEM
maby to download another ver from htc ?
daniel
http://rylwy.com/
Aug 14, 2009 | HTC Touch HD Smartphone
CALL CONNECTION PROBLEM
try resetting ur mobile to company setting. dont install 3rd party softwares
Htc stopped working it hangs on home screen
i had a hard time understanding your question- but iim guessing its a software glitch.... what i did to reset mine was redownload the telstra rom from the htc site (htc.com/au/- then go support- then in dfrop down choose htc touch hd- then click download on htc toucch hd rom upgrade asia- then choose telstra settings and download- should be like 100 odd mb.... once installed connect hd to com via active sync (make sure more then 50% battery) and open up this rom update... follow installation instructions and let it run (all automatic- only for htc touch hd tesltra bought in aus) - be aware that this will wipe all stuff on the phone (not memory card) ie calendar contacts (so backup using active sync b4 update your rom) after all this turn on your phone again and it should start up like the first time u ever turned it on ie touch calibration and time/date etc (this should fix any software glitches)
May 22, 2009 | HTC Touch HD Smartphone
I am unable to synchronise my HTC Touch HD with vista on my computer. Keeps giving me an error.
have u installed the software from the given CD with ur phone?try it, may work.if it doesnt then try downloading the software from the net.i havnt heard of this problem before.i myself hav an htc touch n syncing it with vista is even easier.
May 04, 2009 | HTC Touch HD Smartphone
HTC Touch HD Smartphone Logo
354 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
