Question about Dell Inspiron 1525 Notebook
Error 2000-142 ,146,147
I have the same problem, your HDD has a bad sector and it is damaged, probably because of some virus. You have to change your HDD.
  • 615 Answers
Start in safe mod or c: and use another comuter to download a recover file from any of the free sites to clean the hard drive
if not start your computer from the CD by going via F2 or delete from starting point and change your setup to start from CD not from your hard drive and then you can run recover on your hard drive.
Posted on Sep 08, 2009
Model RDXV59DTKB2 HDD/VCR. On HDD playback it has started,after varying periods of time, to freeze the picture. It can only be restarted by using FF and then Play.
You should be talking to Toshiba support, It could be a bad hard drive having trouble with sectors lost and access. Same as in computers. The way to eliminate hard drive errors is to do a low level format but that just maps the bad sectors into the bad sector table. When the drive starts to fail like this then it is time to not try and fix it as it will continue on this path as the errors migrate across the media disc but to replace it. Low level format is just putting off the failure until the errors become too many to deal with. Probably a Seagate drive- you don't buy them you only rent them for a small time. I stopped buying then at all. Made in China is all you need to know.
Mar 12, 2016 | Toshiba Televison & Video
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
External Hard Disk
1. External powering try changing the adaptor 2. Powered by USB try changing the USB cable 3. Try connecting to other computer 4. Check for any specific error displayed by Mac or ur PC 5. Try changing the disk name assigned to ur external HDD using disk management in PC 6. Hardware problem if under guarantee get it changed else go for data back up and solve if any bad sectors have come up in the HDD 7. You can check for software a that try to repair bad sectors in a HDD but it takes lot of patience for the same
Jan 01, 2014 | Western Digital Computers & Internet
Wd hdd, no bad sectors, but still blue screen error??
Most people don't know how to look for any trojans, they get all the wrong antiviruses and miss all of them. try spynomore and tell me what it found
Dec 01, 2013 | Western Digital Computers & Internet
Error bcd 0xc0000034
Its either some files are missing that requires your device to boot up or your HDD may have badd sectors. Hopefully its not bad sectors. Try reinstalling your Operating System. If it does the same, your HDD have bad sectors. Then try a HDD regenerator software.
Nov 22, 2012 | Computers & Internet
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
Error code 0f00:0244 during hard drive diagnotic test
problem caused by microsoft,
take to dell and demand the hdd be replaced with a new PE windows xp installation.
if they refuse to do this, consult legal advice as the problem is caused by dell and microsoft transfering and manipulating data between the os and the bios via the ntfs file system (recovery) and the hal.dll file.
problem exists because: ntfs file system can manipulate data sent and recovered to the bios, if for instance your dell laptop etc shut down due to low battery then the bios data and the os data would be out of sync, therfore the operating system would render the previous sector that held the data on the hdd as a 'bad' sector and would then use another 'good' sector to transfer data between os and bios at startup and shut down.
as soon as all good sectors have been used, the bios and the operating system will be out of sync and the hal.dll file or the ntfs file system would not allow the operating system to boot because of the data lapse.
demand a new hdd from dell with their OEM PE windows xp installed, if they refuse, then sew them for damaging your hdd by using a virus type file system (virus is how it works, so in release notes on most websites refer to this) which corrupted your hdd's life expectancy.
chalenge microsoft and dell to refute your alegation in court, after all your claim will make them want to settle out of court instantly...
good luck, and don't be afraid of the challenge against microsoft or dell, as a consumer you have rights and your rights are what is at the interest of the law........
Dec 12, 2008 | Western Digital Caviar WD1600 (1600YD) 160...
Dell Inspiron 1525 Notebook Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
