It says there is a paper jam but i cant find any paper
  • 6 Answers
Sometimes this may happen to solve this just remove catridge from printer and again keep it in position. Even after this the problem persists their may be gear problem so go to service centre
Posted on Sep 08, 2009
The orange light flashes three times and it cant print and there's no paper jam
Did you remember to open the door for the paper to exit? Otherwise, if there's no paper jam check the paper path for debris; the sensor(s) might be gunked up.
Mar 03, 2015 | Canon Office Equipment & Supplies
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
Machine says paper jam but cant find any paper stuck?
While working with your Samsung printer you may encounter a paper jam. Paper jams are usually obvious, but sometimes you may face a situation when there is no indication that the paper has jammed up the printer, in that case, open it up and visually inspect it to search for the jammed paper.
Nov 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
We have a paper jam according to the display but have found small pieces of paper tucked away but cant find any more is there a reset or is there somewhere more may be that we cant see/get to?
If your machine is detecting a jam with no obvious signs of paper, you most likely have small amounts of debris or dirt blocking the jam sensor. I suggest manually feeding a piece of thick card stock through the paper path, then spray the path with some canned air, as this will act to clear any dirt blocking the jam sensor.
-David.
Nov 03, 2010 | Samsung SF-340 Plain Paper Inkjet Fax
Cant see paper jam but when I try to copy I get paper jam message
The paper sensor flag is most probably jammed. This will require you to take it to yor closest repair centre. Ths uually happens when you had a paper jem and pilled the paper out in the wrong direction.
May 20, 2009 | Office Equipment & Supplies
False paper jam
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Nov 17, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Oct 15, 2008 | HP Deskjet 2360 InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
57 people viewed this question
k24674
