Question about AEG Santo 7085 KG Side by Side Refrigerator
Rising temperature fridge part - not freezer - AEG Santo
Hi We have a similar problem. About 4 - 5 times that we've noticed over a period of about 6 months (it started in March 2009), the fridge part temperature starts to rise inexplicably (eg not because hot things are put in the fridge, or it is overloaded etc) from the standard 5 degrees to 10, 12, even up to 15 degrees. When we then try to reset the temperature, it appears the fridge doesn't respond immediately, it takes sometimes days for the temperature to go back to "normal". However, when it happened again last week, the temperature went back quite quickly. The engineer that came (we live in France) said he didn't know what the problem was, and could only suggest exchanging the electronics. When we had the engineer round first time, he also didnt know what to do, and did nothing. The fridge was still under guarantee, now it isn't... pretty pissed off about it, as it is an expensive fridge! Any advice appreciated and would love to know whether Laurapindr lady still has same problem. Kind regards marianda
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
How do i set my temperature on my fridge freezer its a aeg santo ?
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Apr 20, 2011 | Refrigerators
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 7085 KG Side by Side Refrigerator Logo
131 people viewed this question
Top AEG Refrigerators Experts
ashburton
Ian Jones
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
