Question about Fuji FinePix S5000 Digital Camera
I get a white screen on my Fuji S5000 camera. It seems as if the zoom gets stuck at max position when the camera is on. This is intermittent.
The dangers of non Fuji power supplies
This is not a DIY job, you need a FuJi digital camera repairer.
May 08, 2013 | Fuji FinePix S5000 Digital Camera
Blank white screane. When i open the camera to take pictures the screen doesnot show any thing it just blank white . the zoom and other thing work
Sounds very strange, hope it isn't serious. Maybe try removing and replacing the batteries. Sometimes a reset helps problems like this. I have the same model.
Jan 20, 2010 | Fuji FinePix S5000 Digital Camera
Only get a white screen when i turn on camera.
I would contact Fuji as S5000 have been known to have the problems with the CCD sensor going out which causes the screen to go white. Fuji's number is:
(800) 800-3854 and select option 1 M-F 9:00AM-8:00PM EST
Sat-Sun 10:00AM-6:00PM
Nov 08, 2009 | Fuji FinePix S5000 Digital Camera
White screen on Fuji S5000
There should be some software corruption in the device go to authorized Fuji service station.
Sep 23, 2009 | Fuji FinePix S5000 Digital Camera
White screen
I have same problem. Everything is ok, but all recorded images and video are white.
Jul 13, 2009 | Fuji FinePix S5000 Digital Camera
Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
May 27, 2009 | Fuji FinePix S5000 Digital Camera
S5000 fujifilm
Was probably caused by the zoom carriage locking on power out due to batteries running low. Turn off camera, tap barrel with solid but non-metallic object and turn on. Did this two times and it worked for me on second.
Oct 16, 2008 | Fuji FinePix S5000 Digital Camera
Re- fuji finepix s5000 digital camera
when the camera is turned on the screen says zoom error and whem pressing the zoom button the camera makes a noise and the lens does not move
Oct 12, 2008 | Fuji FinePix S5000 Digital Camera
White screen, white photos
This is a CCD sensor problem ( see enclosed image ) ; has to be replaced. Contact Fuji agent in your area because this problem on this model is repaired under warranty ( the manufacturer has installed a faulty sensor when the camera was manufactured ).e159388.jpg
Feb 02, 2008 | Fuji FinePix S5000 Digital Camera
Fuji S5000 - Max XD card capacity?
don't remember off-hand, but you can download fuji's xd compatability chart pdf here: http://www.fujifilm.com/... .../fuji/epartners/proPhotoProductS20DataSpec.jsp
Sep 04, 2005 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
244 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
