Question about Yamaha 12V Air Pump
Bad /non starting
I just purchased 80s 2stroke 30 hp manual.it started 1st timeat pre owners.as they do.he told me dont use choke,anyway.i switch on and pull and pull,good comp.no fire up,not even splutter until igive halve choke /pull once push in choke 3/4hand throttle 1/2pulls and it fires up. even when warmed up bad starting/.previous owner said he thought when priming the fuel up bubble felt soft /so gave me some gaskets anddiaphram for engine pump.but said i should not need them yet? so did not fit them yet help ...im a lorry/car mechanic b4 i retired but aint got much idea on outboard ps i did addjust mixture after first time i got it started as prev owner said although engine 100/1 mix. he always run at 50/1 which is what i done fully in 1.5 turns out to run smoother .once in my starting attempt plugs flooded fitted new ones /also checked new ones during procedure they lookd quite wet dried them and it started after few pulls but still bad starting thanks fred turner
  • 677 Answers
Wow!!If you live in alaska is diff. to florida.The usual in warm weather is;Choke/half on,1/4 throttle.2 pulls..Should start.Make sure before you do all this,the fuel bulb is totally primed.The motor is born to run at 50/1 fuel mix.If you changed the carby mixture,dont run the motor untill its set back to standard.It may do some damage.The oil is there to lube the pistons etc.the carb mixtures dont often need to be touched.Before you do spend dollars,try a different fuel lead that does prime up the fuel.Be it a friends or the local shop.They should help.Hope this may help
Posted on Sep 08, 2009
I have a CR80 and it is impossible to kickstart it when it's cold. The best way is to go downhill and put it in gear to start. Someone here who has an any thougts about what I can do to kickstart my
make sure the choke is working ! look through carb intake and see if you get full choke when on ? clean the carb out and fuel tank , replace fuel if older than 6mths ! only use race 2stroke oil ! if all ok then check compression is above 100psi as below is bad for a 2stroke ! P..
Dec 12, 2013 | 2002 Honda CR 125 R
When i start up my kawsaki kx 250 2stroke with the choke on it revs real high until i push it down is this normal
Yes.... try to turn the choke off as soon as possible after start, a cold motor reving hard is not a great idea!.
Cheers.
Nov 29, 2013 | 2007 HM CRE F250R
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
I bought used and saw it start on the first pull before I decided to get it. Since I have been home I cant get it to turn over. I dont have a manual and may be missing a step.
1st clean your plug becauuse if you have been trying to start it and it didnt it may be fouled. remove the plug and wiire brush the electrode then wipe clean. if there was wet fuel on it that isnt a bad thing-black oily caked on stuff would be. Now close the choke turn the switch on put it on the ground and with your foot on the handle pull the rope.
good luck.
Sep 02, 2011 | Ryobi Garden
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
May 23, 2011 | Mantis 2-Cycle Tiller
I have the Morrison BC 260B S2 Weed Trimmer but I don't have any instrucions for its use. I need to know what the mix of 2-Stroke petrol is and its general operation. This is not mine and the owner doesn't...
I have one of these. The mix is 25 to 1. Before starting use the primer bulb to get fuel through; it says to turn the choke to limit the flow, but I've found mine starts easier with the choke open. To start, flick to on/start position, hold the (safety switch?) flush with the spine, and give it a yank.
Sep 04, 2010 | Homelite Mighty Lite Lawn Trimmer
Does a 1985 60hp merc have a choke to help start it or how do I go about doing this yes Im a new boat owner of this kind anyways :)
its on the ignition key ! as you turn it on to first position you then push the key in then as it starts let go and with the control lever on a slight high tickover you mite have to dab the choke a couple of times till it ticks over ! dont over choke or you will flood the plugs ! less is best and just let it warm up before setting off !
Jun 11, 2010 | Light Outboard Motor Boat Bass Fishing...
I own a mccullogh 610 pro mac chainsaw left by the previous owner of our house. Unfortunately, there is no user manual. I am not familiar with chainsaws and am having trouble starting it. I put in a new...
You do know a chain saw is a 2-cycle engine and requires a mixture of Fuel and 2-cycle oil? This saw is probably 40:1 (1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil).
My procedure is better than the one in your manual anyway. LOL
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Feb 23, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to know the procedure in starting a Coleman Generator 5500/6875 11.0 hp Tecumseh. I just purchased it and the previous owner lost the manual for instructions. Please help me. Dolly
I'm not familiar with this particular generator but starting most of these is pretty much the same.
Turn all switches to the generator OFF locate the Carbuerator and put the choke on if it has a small bulb pump it a few times, now here is a trick I use I buy a can of starter fluid and spray a quick spray close to the air intake or air filter. This should work.
Feb 24, 2009 | Coleman Powermate Premium Plus 6250W...
Yamaha 12V Air Pump Logo
119 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
