Question about Honeywell Programmable Thermostat Heater
Unable to get Braemar Spectrolink thermostate to switch to auto
Have just had the thermostat installed for our new ducted gas heater model TH320NG, have set time and date etc but cannot get the unit to switch from manual to auto. When pressing the appropriate button (unit door open) it just switches between Home and Away
  • Catherine Jul 23, 2012
    I just found the solution here: from Alan111S Forum Regular http://forums.whirlpool.net.au/archive/1... We moved into our house and I couldn't get our Spectrolink controller to switch to Auto. Mine has the little peg on the door broken off. This means the Home / Away button does not function for Man /Auto with the door open. A Braemar Technician told me that one can press and hold the Set button then quickly press Home / Away and the system should switch from Manual to Auto. This didn't work for me initially but after following the procedure above to restart the controller, I was able to get the Man /Auto switch working. It saved me $200, because I would have had to replace it otherwise.
I have exactly the same problem, did you ever get an answer to this issue?
Posted on Oct 25, 2010
I have the same problem too. Did anyone get a solution for this?
Posted on Jul 23, 2012
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
I have a Braemar Spectrolink Controller, which has suddenly lost all power and the display is completely blank. I have removed the controller thinking that there would be batteries, but where the batteries...
it gets its power from the unit via the data cable. go on the seely international website or the braemar website and they can put you in contact with another dealer in your area. get it fixed while still in warrenty.
Feb 19, 2011 | Honeywell Programmable Thermostat Heater
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Spectrolink heater won't start
The Technician or the F***ing Person who cleaned your ducts messed up the Sensor that verifies the temperature
Apr 21, 2010 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
740 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
