Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Print size is so small I can't read it on my Kodak all in one printer
3 Suggested Answers
keithd2704
  • 56 Answers
SOURCE: after placing two new cartridges in printer, printer will not pri
Sounds like the print head is either clogged or the replacement cartridges you purchased are dry/defective. Try performing a head cleaning cycle and check the cartridges for proper ink flow. To do this, pull the cartridges out and blot them on a paper towel. If the color flows fine from the cartridge, then most likely there is dried ink in the actual printhead and it will need to be cleaned.
Check this out and see if it corrects your issues.
Cheers,
Keith
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: Printer prints too small
open the print preview by clicking on to the drop down arrow on the right hand side of the printer icon which you can find on any web page or email or a document that you are trying to print from on right hans side top. on the top of print preview window you would get different options .there is an optio which is for the font size/ by default it would be fit to page / change it to 75% or more according to your needs and click on the print option ans see what happens /
please let me know whether it worked or not /
i have other resolutions as well
thanks
Posted on Aug 29, 2009
How do i make my print larger onmy kodak esp3.2
I depends upon what you are printing from. For example, if you are printing from a web page, sometimes there is a selection available on the web site to increase the size.
If the problem is the size that is printing out, I usually do a "cut and paste" of the text from the web page and then paste it onto a blank document page. You can then change the font and/or size of the text.
One other suggestions is in the "printer" settings, select the choice for "no borders" or "no margins" and that will allow the text to expand slightly.
Sep 21, 2014 | Kodak Office Equipment & Supplies
When i print something on my printer the letters are so small i can,t read it
go into your printers home page click on properties scroll down font size or fit to page will want to be set at approx at 85% or larger depending on paper size
Oct 05, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to cancel a print job on the HP officejet 5610 all in one pri nter
The user manual for this printer is here: http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
On page 4, the cancel button is marked "11" on the diagram.
Jul 28, 2011 | HP Officejet 5610 All-In-One InkJet...
Tenho uma D7160 com error 0cx18a0201 o que pode ser
un install the software and restart machine.then unplug it from the computer.
start the machine the insert the cd in the drive and install the software untill it ask you to plug the pri nter.
after complete installation please go to start menu and open printer and faxes and set it as a default printer.
if it refuses try print and change the printer type and it will work thank you.
May 13, 2011 | HP Photosmart D7160 InkJet Printer
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
Why does my printer print so small you cannot read it?????
hi this could be due to the settings in the program you are using, say MS WORD, on the top of the menu it should have a font size that is next to the type of font you are using, click on the arrow to the right of the number, normally default size 10, and there choose what size you require hope this helps
Feb 28, 2010 | Kodak Office Equipment & Supplies
thanks
Aug 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Is it possible to print 5x7's with the kodak esp5
Print from your computer :
open the picture you want to print
go to :
File
Print
Properties
another windows will pop up and under general you will see different print size and you can chose there the different paper size and print size.
Apr 11, 2009 | Kodak ESP 5 Printer
Not printing at all now.
If the size or resolution won't work right then it is usually a software issue and most probable fix is to install a new updated driver for your model and your operating system. Try googling your printer model for a driver(sample is Kodak X5300 driver) and you should find one free easily. Download and install the driver and this should fix it.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't setup a page to print
IF YOU CHOOSE TO VIEW A PRINT PREVIEW BEFORE YOU PRINT A LOT OF TIMES YOU WILL BE ABLE TO ZOOM IN OR OUT OR ADJUST THE SIZE COMPLETELY BEFORE YOU PRINT IT OUT
Jan 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
