Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
The display wont change even when i close the phone...
The displey is not switching to the outer screen even after closing the phone... recently changed the body... might've missed some part of the phone... i'd like to which one....
  • thenewempero Sep 08, 2009
    i disassembled and reassembled the whole phone just last night... all of them are properly connected...
    Sniper:
  • 75 Answers
The strip is not connencted completely with the jack check and insert strip again..
Plz dont forget to rate
Posted on Sep 08, 2009
  • Farhan Jabbar
    Farhan Jabbar Sep 09, 2009
    brother then may b your strip is damaged.may b you will have to change strip.Its better to take you phone to a repairing shop
My dishwasher display close door even when the door is closed.
there is a switch which the PCB has to see is electrically closed .the outer physical means nothing to the inner works of the controls
Aug 12, 2015 | Dishwashers
Razr screens
Sounds like the phone is defective..Contact your cell phone provider to see if they are willing to replace it for you...I believe most company gives you one year warranty for the phone...
Hope that helps
Please rate accordingly
Thank you
COmputerrep
Mar 20, 2008 | Motorola Mobility RAZR V3
Inner display backlight works, but it doesnt display anything, could this be the cable sockets problem? Thank you for help.
If you look very closely (check in different lighting conditions), do you see anything on the outer screen at all? You probably won't be able to fix this yourself, but you might be able to determine if something is loose. Press a button on the phone, which would normally make the outer screen light up. Hold the phone firmly in one hand and smack it into your other, outstretched hand at different angles (i.e. smack the right side, left side, top, etc. several times). If the screen comes back on even for a moment, then something is just loose, and the repair shouldn't be costly. If you can see a faint image on the screen in some lighting condition, but smacking the phone doesn't help, then the problem is the backlight and you will probably need a new screen. If you can't see anything on the screen at all, and smacking doesn't help, then the problem is unknown
go to nokia care
Nov 22, 2014 | Nokia E90 Cell Phone (Unlocked) - Black
The Outer screen is blank (drak)
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 10, 2010 | Nokia E90 Smartphone
Front Panel not working
there is one magnet placed in the cover when u rmove the front portion the magnet will fall off without your knowledge so plz close cover will be displayed put new magnet it will be allright
Jul 29, 2008 | Nokia 9500 Communicator
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
No Display for samsang sgh a 800
my Samsung A800 also lost its inner display recently. When I open the phone, the inner display lights up but fails to show any image. Outer display is mostly OK, once it had trouble to "lock" the image and after opening and closing the phone a few times the outer display showed the image with light and dark bits inverted.
Switching phone off and on restores the inner display most of the time, but the image only lasts until I close the phone.
Jun 20, 2007 | Samsung SGH-x427m
Outer screen not working
You will probably have to open up your phone and check the connection with the wires that go to your screen and see if their jared lose. Sorry but I don't know how to seperate it. But this is only if you dropped it and have insurance.
Feb 07, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
