Question about Panasonic KX-T7453 Corded Phone
Night ring The phone system's night ring is set to come on at 5:00 PM. Several people work past 5, I would like to change the activation time for the night ring to 6:00 PM. Can I do this, or is it something I need the "phone guy" to do?
    Problem Solver:
  • 14 Answers
The manual day/night switch can be made from the operator ext (usually 101). This will over-ride the preset schedule.
[SHFT], [FEAT], scroll jog dial until you see Night Mode, [SEL], then press [0] for night or [1] for day.
To change the automatic start and stop time is, indeed, a phone guy (or gal) function.
Page 4-33 in the System programming manual.
Posted on Jun 27, 2008
My phone is not ringing, what should I do. I have a KX-TGA41OC
    A)The ringer volume is turned off. Adjust the ringer volume (page 16).
    B)Night mode is turned on. Turn it off (page 25) A)Adjusting the handset ringer volume
    While the handset is ringing for an incoming call:
    Press {??} repeatedly to select the desired volume.
    Programming the volume beforehand:
    1 {MENU} #160(include the # key)
    2 {??} Select the desired volume.
    3 {SAVE} {OFF}
    B)Turning night mode on/off
    1{MENU} 238
    2 {??} Select the desired setting {SAVE} If you select "Off", press {OFF} to exit
    3 Enter the desired hour and minute you wish to start this feature.
    4 {AM/PM} Select "AM" or "PM" {OK}
    5 Enter the desired hour and minute you wish to end this feature.
    6 {AM/PM} Select "AM" or "PM".
    7 {SAVE} {OFF} When the night mode is set, the night mode indicator is displayed
Dec 18, 2014 | Lands Phones
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Sep 17, 2014 | Hardware & Accessories
My phone is panasonic kx-t7730 white advanced system HYBRID SYSTEM it does not ring in the day time mode
it may be the battery for its memory be dead...if this is true the phone installer can straighten it out for you
Jan 18, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
Panasonic pabx - KX TA308 The system is set to ring on all phone in the evening. So we need to change the time in the system to coinside with daylight saving. How Please? In the past we have paid a...
From the Manager or operator's phone (usually ext 101) press PROGRAM and dial 0 +
Year (00-99), Month (01-12), Day (01-31), Day of the week (0-6: Sun-Sat), Hour (01-
12), Minute (00-59), AM/PM (0/1) and STORE.
This changes the time, but you may have CID changing it back. That event usually takes place about the first call after 2 or 3 AM daily.
Oct 14, 2010 | Office Equipment & Supplies
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Panasonic KX-T7453 Corded Phone Logo
404 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
