Question about Dell Latitude D600 Notebook
Battery light with lightning symbol flashes red and green
    President:
  • Dell Master
  • 2,022 Answers
Remove the battery and just connect the power cord and see what is the status.may be your battery is not getting chage or it is faulty.
Posted on Sep 08, 2009
I have a easy share c533 and thought it had capability of the flash NOT going off - apparently i am hitting the red eye button - it looks like a flash zaggy arrow pointing down - what is this where is the...
The lightning bolt is the fill-flash symbol. Red-eye reduction is the eyeball symbol. Flash off is the lightning bolt in a circle with a slash through it. There's also an auto flash mode, represented by a lightning bolt with the letter "A".
Repeatedly press the flash button on the top of the camera to cycle through the flash modes.
Dec 11, 2010 | Cameras
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Red light flashing on far right symbol/battery or charger going ?
this happiness when you've used the laptop off power for some time. it indicts your battery levels. when the battery level is low to a certain %ge then it warns you before its totally empty. always power up your laptop whenever it lights or save your work in order not to lose unsaved data.
May 26, 2009 | Dell Latitude D600 Notebook
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Dell Latitude D600 Notebook Logo
254 people viewed this question
Alun Cox
