Question about Acer Aspire One AOA110-1588 Notebook
I cannot run defragmentation. - Acer Aspire One AOA110-1588 Notebook
  • lgbrown99 Sep 08, 2009
    It says Disk Defragmenter has detected that Chkdsk is schedule to run on volume c:
    Please run chkdskf/f
  • Roberta Smith
    Roberta Smith May 11, 2010
    what error message are you getting.
    Genius:
  • Acer Master
  • 1,252 Answers
Disable antivirus , also change the power option
Posted on Sep 08, 2009
How to defrag on acer extensa 5620
You can use the built-in Disk Defragmenter to Defragment your system.
To defragment your hard disk
  1. Open Disk Defragmenter by clicking the Start button. In the search box, type Disk Defragmenter, and then, in the list of results, click Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Once Windows has finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
4. Click Defragment disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
GuruAid
May 05, 2014 | Acer Extensa Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
Fix syncing issues?
Clean up System & Sync Issues Folder Microsoft's Disk Defragmenter, which is built into the operating system, makes computers run faster. It does this by reconfiguring where data is stored on the drive. This will speed up the hard drive and fix syncing issues.
Click "Start." Type "Disk Defragmenter" in the search bar. Left-click the result labeled "Disk Defragmenter." Click on the "C:" hard drive. Click "Defragment disk." The process will take several minutes to complete.
Feb 02, 2013 | Computers & Internet
My N100 notebook is very slow in process
if it is a windows computer, try running defragmenter and disk cleanup.
to run defragmenter, in the search box in the start menu (in vista and windows 7) and search "defragmenter" select the c drive, and defragment it.. while you're at it, set up a weekly defragment with the defragmenter schedule.
To run disk cleanup, search for "disk cleanup" in the same search box. select the c drive, and check all the things you want to clean up.
you can always just do a scan with your antivirus to check if theres a virus slowing your system down.
Oct 07, 2012 | Samsung N150 (36725723009) Netbook
Problem with pc hp compaq nx9010...programs work but runs down and shows non responsive program..in what may be problem??
If your computer shows a non responsive program whenever you run one, you might be having a lot of file saved on your computer or maybe the memory of your computer is almost full. What you can do is to run a disk defragmenter as it will help optimizing the performance of your computer and delete some unwanted files or folders and programs as well.
To run disk defragmenter:
- click start > all programs > accessories > system tools > disk defragmenter
To remove programs:
- click start > control panel > add remove programs / programs features > select and uninstall a program
Cheers.
Mar 05, 2011 | HP Computers & Internet
I deleted my game nfs(3.96gb) and since then there have been problems.when i open the icon my computer,it loads too slowly.plz help.
pls follow the steps:
1. download wise registry cleaner. install & run it. delete the registry values, which are safe to remove (it will show u in green)
2. after registry cleanup, run disk defragmenter. START>ALL PROGRAMES>ACCESSORIES> SYSTEM TOOL> DISK DEFRAGMENTER
3. restart ur PC.
All the best
Aug 17, 2010 | Computers & Internet
Disk defragmenter has detected that chkdsk is scheduled to run on volume : (c:) Please run chkdsk/f.
If you want to do Disk defragmentation Plus Check Disk, " PerfectDisk 10 Professional" is what I recommend.
Here is the download page
Please fill the rewuired form with your E-mail address and your country.
Press download.
That's it.
Dec 27, 2009 | HP Compaq Presario V3016US Notebook
Slow connection
defragmentation is worth performing even tho it takes a long time, id look for a different software other than the windows defragmentation tool
some freeware here
http://www.snapfiles.com/Freeware/system/fwdefrag.html
hope it helps
Mar 24, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Hard drive problems. Technical imformation (0x00000024) (ox00190444,0x860cDEE8.0x00000000)
ok my friend
go to safe mode
disable every security system (antivirus or antispyware).
run defragmentation on ur C drive
by RIGHT clicking on my computer and then select manage
select disk defragmenter and continue
at the end
go to start
go to run
type cmd
hit ok
type this command
Chkdsk /f /r
hit enter
reboot the computer
hope that will fix it
cheers
Aug 30, 2008 | Gateway Computers & Internet
Acer Aspire One AOA110-1588 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
