Question about Samsung SGH-G600 Cellular Phone
I want to use the sped dial but o2 have blocked them to use for their service numbers can you help, i am a novice with all things tecno thanks
I want to delete all blocked #'s in my Panasonic home phone
Hi dear Lavon Bonar:
RE: Unblocking phone numbers on your Panasonic landline:
Dial *60 to access blocked numbers:
Your Selected Call Rejection Service is probably now ON;
To TURN OFF Call Rejection Service, dial 3.
OR
To REMOVE ALL blocked entries Dial 08*
That's it. Glenda Gammel 9/21/2017
Sep 08, 2017 | Panasonic Lands Phones
Tip
How to Block a Phone Number With AT&T
<a><img src="block-phone-number-at_t-200X200.jpg" /></a> Call blocking is an easy way to deflect unwanted calls. <span></span> jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a04/th/aq/block-phone-number-at_t-800X800.jpg'); }); <p>If you're an AT&T customer and you're tired of receiving calls from companies that try to sell you things you don't want or from people who simply pester you over the phone, the solution is simple. AT&T has a call-blocking service that you can activate in a few simple steps so you won't have to ignore the phone or hang up on people.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span>Difficulty:</span> Easy <span>Instructions</span> <ol> <li> Dial "*60" and listen to the voice instructions.<br /> </li> <li> Press "3" to turn your call-blocking service on.<br /> </li> <li> Press the "#" button.<br /> </li> <li> Dial the telephone number that you want to block.<br /> </li> <li> Press the "#" button again to block the number<br /></li></ol>
on Jan 12, 2011 | AT&T Blackberry Curve 8300 Smartphone
T mobile login to my account
when you make a call from a T-Mobile device, you may choose to block your Caller-ID information, which you can generally do by dialing *67 prior to dialing the called party's number. Refer to the specific instructions for your communication device regarding Caller ID Blocking for other or different dialing instructions. Please note, however, that Caller ID Blocking does not prevent the display of your information when you dial certain business numbers, including 911, 900 numbers, or toll-free numbers. For more specific information or instructions, you may reach a customer service representative by dialing 611 from your T-Mobile phone or 1-800-937-8997 from any phone
Feb 19, 2014 | Computers & Internet
Block specific number phone
it depends on a lot of things.
if you are with a traditional phone service, then check their website for the code to dial . in some cases you will need to call them to block calls and charges may apply.
If you are with voip service then you can contact them for the procedure to block or check their website.
Dec 07, 2013 | Lands Phones
I don'tknow how to block a contact on a lg arena phone
please follow the steps carefully
  1. Step 1 Call the T-Mobile customer servicemag-glass_10x10.gif phone number located on your phone bill. Tell them you would like to hear about T-Mobile's call blocking service. The customer service then tells you how you can block all the calls coming from your T-Mobile cell phone by adding this service to your plan. When you select this service, anytime you dial a number from your T-Mobile cell phone, the number will come up Restricted on the call receiver's caller ID.
  2. Step 2 Dial *67 prior to any number on your T-Mobile phone that you want to block, if you want to just block one call at a time and choose which numbers you dial are blocked. This is another way you can call someone and to have it appear as a Restricted call on the other end.
  3. Step 3 Program your T-Mobile phone to block all calls to any one individual. Do this by tapping Add a Contact on your T-Mobile phone. Type in the name of the person you want to call. Then tap Add Phone Number. Punch in *67 then the number.
  4. Step 4 Tap the person's name to call him, when you have the person's number programmed into your phone with the *67 first. Every time you tap the person's name, you will be calling him from a blocked number.
hope you dooooo...
please rate me
thank you
Sep 20, 2009 | LG KM900 Arena Cell Phone
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
SAMSUNG SGH-E250 puk blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give me a good rating on my profile.
Kind regards
Dustin Ellse
May 06, 2008 | Samsung SGH-D500 Cellular Phone
Lexmark x4270
HOLD DOWN THE SPED DIAL NUMBER WHEN IT BEEP THEN ENTER THE NUMBER WITH AREA CODE YOU WANT TO DIAL, WHEN FINISHED HIT SPEED DIAL AGAIN.
Oct 12, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Samsung SGH-G600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
