Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Tries To Come on, But Screen Will NOT Light Up!
By wazhis on Dec 09, 2007
My Cell Phone was Working Fine & Then It Just went off, I thought , But it was on But the screen Will NOT Light up OR Come on. & The Phone won't work!
Thank You.
Teresa
Same Problem
Oct 11, 2008
-   i can not turn on my phone frozen and took out bat no luck tryed sim and not luck is there a reset-   vwphillip
Oct 11, 2008
-   keypad will light up but scream remains black it wont turn on the keypad just stays litup-   bubblebobbin
Aug 21, 2008
-   my screen is black but the phone works.-   Guest
Aug 02, 2008
-   the screen will not light up but the keys will-   higff
Jul 04, 2008
-   MY SCREEN WONT COME ON BUT THE PHONE DOES-   TAHERAH
Best Solution
posted on Aug 21, 2008
Helpful)
Daelmyth
Rank: Guru
Rating: 87%, 61 votes
Replace Motorola V3 RAZR Keypad flex and Left Knuckle...
Need a small flat tip, T3, T5, and T6 torx screwdrivers. Remove battery cover and battery. Remove two T6 screws holding the main board cover in place. (will not need T6 anymore for disassembly). Lift gently where battery contact terminals are. Will expose where main Keypad flex plugs into main board. Genty unplug this flex with a small screwdriver. (CAUTION, THERE ARE SMALL COMPONENTS ALL AROUND THE PLUG ON THE MAIN BOARD - BE GENTLE!!!) Once the main flex is unplugged, gently work the back housing piece and main board until it releases from the phone. Set this aside. Looking at the back of the phone now, there will be a total of 8 metal tabs. Two at the top (under sticker), two low on the sides, and then two on each side of the phone under the label. Bend these straight up. This releases the keypad cover, exposing the keypad flex.
With the phone open, looking at the main inner screen, 4 rubber bushings (1 at each corner) cover 4 T5 screws. Remove the bushings and the screws. Close the phone to now be looking at the outer screen. Start at the top, by the camera lens and gently work off the outer cover. With the screws gone, it is just snapped into place.
This will expose the upper flex connection. It will be on the top left if you are looking at the outside screen with the camera on the top. The camera will plug in on the top right. Unplug the main flex and the camera. Remove the camera. (should pull straight out when unplugged. Remove rubber cushion under camera. There will be a small thin metal piece on the right side of the whole the camera was in, remove that.
With the main flex unplugged, looking at the top left of the closed phone, you should see the ears of the left knuckle (chrome) if it is broken, you might not be able to see the whole thing and pieces might fall out. Using the flat tip screwdriver, push this piece out of the left side of the phone.
Turn phone back over to be looking at the sticker in the back of the phone with it closed.
T3 screw in left side top, remove. Hinge grommet should come out relatively easily exposing the tip of the spring loaded hinge. Hold the phone open at a 45 degree angle and depress the tip of the spring loaded hinge. When it is depressed far enough, you should be able to work the top and bottom halve's of the phone apart. Put the top half aside.
The bottom half is now ready to remove the keypad flex. It is held in place by some pretty decent adhesive. Look very closely at how it is mounted into the housing, how the plugs run through, etc. If you are sure the keypad flex is damaged, you can just rip it off. If not, go very slowly pealing it up and working the plugs through the housing. One small tear can kill it.
Keypad flex and left knuckle can be found on ebay. search for...
Motorola RAZR V3 keypad flex
Motorola RAZR V3 Hinge set, or left knuckle, or left hinge.
Follow steps in reverse for reassembly.
If you want it done for you, contact Wireless Unlimited, Cell phone and computer repair.
www.wirelessunlimitedinc.com, www.myspace.com/wirelessunlimited.
423-913-0488
M-F 10am to 6pm.
If you mail it to them, they can have it fixed and in the mail back to you same day they recieve it.
Please contact me with any questions about the above solution and please don't forget to rate.
Comments:
Aug 21, 2008
- Also, when reinserting the left knuckle, be very careful not to pinch the new cable. The left knuckly (left hinge) should be inserted after the keypad flex is replaced and the two halves are back together. If you are not careful when reinserting this left knuckle, you could very easily damage the new cable.
Was this helpful?
Yes
No
Solution #2
posted on Dec 09, 2007
Somewhat Helpful)
barry123
Rank: Master
Rating: 81%, 27 votes
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Was this helpful?
Yes
No
Solution #3
posted on May 03, 2009
Not Rated)
AWARAPAN
Rank: Master
Rating: 77%, 23 votes
Try the link . . . http://www.Motorola.com/Razav3
For find best solution.
24
Was this helpful?
Yes
No
Solution #4
posted on May 02, 2009
Not Rated)
nreu
Rank: Master
Rating: 86%, 11 votes
Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3 is hardware problem. Such as won't charge, black screen etcFor solution of these hardware problem just click here.
For any other problem of Motorola RAZR V3 like software problem or other just click here.
Was this helpful?
Yes
No
Solution #5
posted on Mar 10, 2008
Not Rated)
Cabinetmastr
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #6
posted on Mar 09, 2008
Not Rated)
hsnow
Rank: Apprentice
Rating: 0%, 0 votes
Yes, instructions please? I can find guides on how to dismantle my phone but I dont know what or where this ribbon is or what I should do with it when I find it.
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
This is a USA phone that wasgifted from my uncle and it is locked. How do i open it
Answer
we just got a motorola razr v3. we want to transfer contacts from the sim card that was in the... (More)
Answer
when i paired my (motorola razr V3)to my chrysler town & country 2007, it does not transfer... (More)
Answer
my phone screen goes white & won't do anything.the buttons r sticking
Answer
what does the icon "EV" stand for on the display screen?
13 Other Users Have The Same Problem - Continued
Comment by yoyo1234, posted on Apr 16, 2008
dido
Comment by Guest, posted on Apr 16, 2008
screen wont light up and i cant hear when ppl call
Comment by hsnow, posted on Mar 10, 2008
Hey so after my last post I did quite a bit more research about this issue and found that this forum
http://www.howardforums.com/archive/topic/1073184-1.html
I would recomend looking at it if you have a similar issue because it had some pretty good information. Basically, from as far as I can tell, you need to check the indicator stickers (the one that is directly below your battery is the most accesible) to see if they are red. If they are, then you have had some pretty significant water damage... which is weird because I discovered mine was half red although it hasnt ever really gotten wet. If that is the case, there is probably some corrosion on that "ribbon" which other places call a flex, plexi, or flexi connector strip that will need to be brushed off with a toothbrush and alchohol. There are plenty of places to find dismantling instructions for a RAZR V3 and so I guess that is what I'm going to try to do. Another situation would be that that flex connector broke or got loose somehow and I guess needs to be replaced. You can find replacements for these on ebay and other sites but I'm not entirely sure what level of skill is required to attach that or repair your or whatever. I'm thinking I will open mine up and try to see if there is any rusting and if not, I suppose I'll give it a shot and try to replace it. Haha my phone is really crappy anyways...
Comment by tha misses, posted on Mar 09, 2008
this phone truely sucks!!!...i just took off my insurence b/c my contract is almost up and the SAME NIGHT, the phone froze and now it wont come back on it just has that stupid little Hello Moto message....plz help i havnt had the phone a good 2 wks yet
Comment by stressn, posted on Mar 09, 2008
Razor was doing great then, like the others, the display light went out. Removed battery & SIMS card for at least 30 seconds.. Thought it was gone until I called myself & my phone "vibrated", a ringtone I did not select for anyone. I rec'd 1 other call, all day, which is not normal for me. So I don't know if the phone is working all the time. I can call out, too, as long as I remember the person's # because I CAN NOT SEE A THING! The one "solution" I read, involving a "ribbon", I guess inside the cell, did not include who does it or where to go. Anyone know? Also, are there any other possible solutions short of buying another cellphone?
Comment by hsnow, posted on Mar 09, 2008
Agh! This happened to me as well. It was functioning completely normal but all of a sudden I opened it and could barely, barely make out what was on the screen. The light will not come on no matter what. The keypad lights work just fine and the phone still works but I cant see what I'm doing whatsoever. Help?
Comment by bcole82003, posted on Feb 25, 2008
I went to turn on my motorola razor phone, and the screen wont light, up. Does this happen often with a motorola razor phone. I have changed batteries switched batteries rebooted the phone, and still no display on the phone.
Comment by Guest, posted on Dec 20, 2007
screen on my motorola lights up only when i half open it. It was working fine and then one day it went out. I have only had it 3 months
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular... Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
