Question about LG Prada KE850 Cellular Phone
LGks360 service detached -phone will not make calls or send texts or turn off in this mode .How to come out of it?
Unable to send or receive text messages message shows unfortunately messaging has stopped
Samsung Galaxy S 4G: Not able to send or receive text messages (airplane mode not enabled)
Hello. It's possible that your cellular service has not enabled your ability to send and receive text messages on their end..
Call your service provider on a different phone to let them know that you are not able to send or receive text messages in all the areas you've tried. Indicate how far away from each location that you are unable to get signal from. If you can not send or receive text messages anywhere at all, this should also be addressed. They may even walk you through resetting your APN settings
In some cases, it could just be the building that you are located in that is blocking cellular service.
Sometimes, it could be a fault of the service provider. They may need to reset your connection on their side. If not, at least you can get them to try..
It sounds like it is not the fault of your phone, but has to do with the Cellular Service Provider.
Jan 28, 2016 | Samsung Galaxy S 4G Cell Phone
Phone says I need to turn off airplane mode to place call.
Well airplane mode disables all forms of outgoing RF from your phone so of course you can't place a call or text. look through your menu and you'll find a place to turn airplane mode on and off. It might be under "settings"
Sep 22, 2012 | straighttalk.com
I have a LGKS360 cell phone. Everytime I try and send a text message, I get the message, "send failed" Please could you help me!
Each telephony provider has a special phone number (called "Message Center") which must be set accordingly before you'll be able to send messages. Call your provider's ClientService and ask them which is the number that must be set.
For example, my telephony provider COSMOTE (in Romania) has +40766000510. Practically, without this number set in the message settings section, no message(s) could be sent!
Jun 27, 2011 | Cell Phones
My phone is not receiving any text messages. It can send them and it can also send and receive calls. What is the problem?
go to your msg settings option check the service number, set the validity period as maximum,message type as text,reply path in off mode and most important is set your character support as gsm alphabet
Aug 14, 2009 | Samsung Eternity Cell Phone
Motorola i930-no texting-originally Nextel-now boost
I had the same problem but I have nextel. I called them and they just told me to send all text messages as 'MEDIA MESSAGES' and it works!
Feb 21, 2009 | Motorola Mobility i930 Cellular Phone
How do you turn of phone - no calls and turn off just roaming?
Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode off.
This will disable the ability to:
Make phone calls
Send or receive email
Browse the Internet
Send or receive text messages
Stream YouTube videos
Get stock quotes
Get maps locations
Get weather reports
When in airplane mode you can still:
Listen to music and watch video
Listen to visual voicemail
Check your calendar
Take or view pictures
Hear alarms
Use the stopwatch or timer
Use the calculator
Take notes
Read text messages and email messages already stored
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Apple iPhone 3G
How can i configure message services to text someone?
First, I assume you have a service provider, a valid cell phone number and that your service provider has enabled text messaging as part of your plan.
To send a text message, go to "Messages", then click "Compose SMS", "[Use Once]", "SMS".
Type the cell phone number of the person you want to send the message to.
Click the trackwheel, then "Continue".
Type a message.
Click the trackwheel.
Click "Send".
If you still are not able to send a text message, you need to verify that "fixed dialing mode" is not enabled. To do that:
Go to Phone Options.
Click "FDN Phone List".
Click "Disable FDN Mode".
Dec 29, 2008 | RIM BlackBerry 7290
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
Nokia95 - 1G card
try network settings change dual to gsm mode
Oct 02, 2008 | Nokia N95 Cellular Phone
LG Prada KE850 Cellular Phone Logo
314 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
