WEN I USE CPU 420 IN 45CMX NO DISPLAY - Computers & Internet
    Sergeant:
  • 270 Answers
Connect the chords correctly.reinstall the operating systems correctly and install the drivers and try again.
Posted on Sep 11, 2009
Toshiba m305 powers on to lines and dark spots and gets darker
first check if the cpu is ok to check the cpu you will have to listen if the laptop makes a beep . when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. if this dose not help you plz mail me on my facebook at nic fourie
Nov 28, 2013 | Computers & Internet
Notebook not powering on.
you must take note to the beep of your laptop. when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max
Nov 19, 2013 | Computers & Internet
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
I have dell power edge 1900, it can not display even though the power turns on well
you must take note to the beep of your laptop. when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. if it dose make the beep then try to connect a normal screen to the laptop.
Oct 26, 2013 | Computers & Internet
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
ASUS M2N VM DVI trouble
You must replace the processor cooler, the fan on it has aged and it's no longer doing its job properly. And use a good thermal paste.
BTW that software was designed to notify you of the temperatures and nothing more, reinstall it immediately.
Jul 09, 2010 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I had a problem in my N76 mobile... Wen im trying to switch on the mobile display remains blank and the um ic gets heat....
I had a problem in my N76 mobile... Wen im trying to switch on the mobile display remains blankand the um ic gets heat...
Feb 25, 2010 | Nokia N76 Cellular Phone
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
I have intel gvsr motherboard hangs every 3 to 4 hrs
Dont overclock the CPU, and underclock the GPU and see what happens... This should solve it, along with adding a fan or two with a thermostat!
Jul 26, 2007 | Intel Motherboard
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
