Question about Eclipse EA3422 Car Audio Amplifier
Car Ampli Problem
Eclipse EA3422 Car Audio Amplifier problem
My sub running on 4Ohm.Rest other speakers do not have an O/p from amplifier. Actually I need to connect these speakers to amplifier. What is recommended speakers to connect this amplifier. Woofer is 1000W/4Ohm
  • 38 Answers
Use x21000w speaker size 10 that is good for your ampli..........theres no over heat because your ampli using a battery of your car thats is 12amp supply your ampli
Posted on Sep 29, 2009
    Problem Solver:
  • 16 Answers
Forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Posted on Sep 08, 2009
How do i set the amp for one 8 ohm sub speaker
If you meant to connect your Sub woofer speaker which has an impedance of 8 ohms , you can use the bridge connection between the two channels to connect.
This will be noted on the output terminals and so the speaker can be bridged between the left and right channels.
Jan 12, 2011 | Eclipse EA3422 Car Audio Amplifier
EA3422 Car Audio Amplifier: Keep popping fuses...
Check your ground and power wire connections. It will most likely be a bad ground, if grounded in the trunk, get a longer wire of equal or greater thickness and ground to either chassis or battery. Also if you have the amp at full gain try dropping it a little back if getting a better ground doesnt help
May 18, 2010 | Eclipse EA3422 Car Audio Amplifier
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Jan 29, 2010 | Eclipse EA3422 Car Audio Amplifier
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    DA 7122
    I have yes, but you have to turn the gain down on the amp below what you normally would
    May 28, 2008 | Eclipse DA7122 Car Audio Amplifier
    Wiring
    The T10001 can drive a load lower than 4 ohms. Wire the coils of the individual speakers in series to make each speaker 8 ohms. Then wire all 3 speakers in parallel and connect them to the amp. This will give you a 2.6 ohm load.
    Dec 01, 2007 | Rockford Fosgate T10001BD- Car Audio...
    Compatibility
    this is a safey feature in your amp. you are drawing too much power for the amp to put out so i shuts off when the breaking point of the total rms calue is reached. i would suggest getting a more powerfull amp, a larger ground/powerwire combo, or a farad capacitor to balancethe powerin andthe power out.
    Sep 04, 2007 | Eclipse EA3422 Car Audio Amplifier
    Problem with an eclipse EA3422 amplifier
    Your problem is with your stereo/radio, not your amp... Take a friend amp and connect it up as you have yours and see if it does the same thing.
    Aug 10, 2007 | Eclipse EA3422 Car Audio Amplifier
    Eclipse EA3422 Car Audio Amplifier Logo
    164 people viewed this question
    Top Eclipse Car Audio & Video Experts
    xxxxxx xxx
    Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
