Question about Maxell MAX556437 3.5" Diskettes, IBM Format, DS/HD, 5 Assorted Colors, 10/Box (556437BX) Media
IBM 3.5 Diskette/1.44 MB Capacity/IBM Formatted. Won't open.
I can't open any of my Diskettes. When I try, a message appears
and reads, " The disk in Drive A is not formatted. Do you want to
format it now?"
Almost two years ago, my PC crashed, and I brought it in for
repair. However, I think after the repair, I was able to open "a"
disk. After removing the disk, I inserted another disk, and upon
opening it... the pictures from the previous disk, appeared.
Is there any way I can retrieve all my old data from these diskettes?
Also, I have a new problem. After having tried to open a total of
four diskettes, my Dell computer's tower, now has a strange hum.
Thank you in advance for any of your assistance,
Respectfully,
EanR@aol.com
    Genius:
  • 1,003 Answers
Replace the floppy drive it sounds as if the drive motor is bad the hum is a inactive drive motor when a floppy is good it will usualy click as it comes on along with a green indicator llight
Posted on Jan 15, 2008
Reader for a square format 5.25 IBM formatted disk?
You can purchase an old 5.25 disk drive that will fit into any PC that has an open bay or swap out the smaller one for the 5.25 one.
Almost all computer shops have lots of them still around.
Mar 27, 2014 | Verbatim 30 Datalife Plus Md2-d Ds/dd...
Cannot access documents on remote diskette drive
ok this is definitely 1 of 2 problems.
1.) the diskette drive is damaged..
2.) the disk them selves are bad. These disk dont last very long and develop a white fungas on the magnetic disc itself.
to be certain get a disc you are re is working ,, and try it on a machine with a drive for it (dont know if they still exist).. if the disc works and does not work on your machine get a new drive..
if the disc don't work well then they are bad.
Dec 29, 2012 | IBM Wheelwriter 70 Series Ii Typewriter...
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
Oct 19, 2011 | Computers & Internet
I cannot format my 16 gb pendrive is show unable to format the pendrive
i cannot open or format my 16gb transend pendrive ...when i tries to open a message appeares " please inset a disc into drive "........plz help me..
Oct 27, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
When I am put my 8 gb Transcend usb deive into pc, the message come ''u need 2 format the disk in drive I:b4 u can use it'' ,ten I click on format disk, a message come ''windows was unable 2 complete the...
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Mar 19, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
8 GB usb pen drive
Sounds like it's fried. Pen drive sometimes go bad, especially is they are pulled out of a machine without stopping it first. Not much you can do, sorry.
Jan 22, 2008 | Electronics - Others
Electronics - Others Logo
114 people viewed this question
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
