Question about Nokia E66 Smartphone
I have nokia E66 iwas maked encryped my phone and momery card .now i decryped phone momery and momery card i appered some tropule in content of momery card not appear and the device not change to momery caid in the messaging thanks
Nokia e66 memory card corrupted
pull out the memory card, and try to read it using a pc (via card reader)
if you are lucky, copy out all the info and format the card.
copy the files back in. pop it back to the phone.
Jun 30, 2011 | Nokia E66 Smartphone
N72 mobile is hanging
enter code *#7370# . but befor remove your Momery card in handset. done handset reset.then chq. virus in momery card. use e scan antivirus in your pc .
Apr 21, 2011 | Nokia N72 Cellular Phone
Nokia e66 knows no sim card..I changed the part of card set and again the same problem...insert sim.. please help
hello dear. nokia e66 sim card ok but memory card insert, memory ic change same problem, please help me...
Apr 15, 2011 | Nokia E66 Smartphone
My nokia e66 suddenly says "remove memory card & press ok".. don't know what the problem is..
The problem is because the memory card is loosely in place. Take the memory card out then push it back making sure that it fits the slot perfectly then you can access your files again with no problem.
Also make sure that you are following the correct way of putting it in as illustrated in the carving at the back of the phone.
Mar 14, 2011 | Nokia E66 Smartphone
E66 shows "Remove Memory Card and Press OK" it has latest software and few apps only. pls help
It can happen at two occasions :
1.Memory card not properly inserted.
2.Ur card slot door is not working properly....
Oct 10, 2009 | Nokia E66 Smartphone
Your memory is not inserted properly. Take it out carefuly, and check if inserted correctly. If problem still there format the memocard - it will also delete its content.
Oct 10, 2009 | Nokia N95 Cellular Phone
No momery card
no memory card inserted
Dec 20, 2008 | Nokia N70 Cellular Phone
Noki6230 delete fhome momery
there is no possible way to format 6230 phone memory. you can manually erase phone memory contents.
Dec 22, 2007 | Nokia 6230
Nokia E66 Smartphone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
