Question about Philips Senseo HD-7810 Coffee Maker
The indicator light continues to blink rapidly
Dear,
We have a senseo HD 7810 coffee maker with a problem.
The indicator light continues to blink rapidly even if we have placed the water reservoir properly with enough water. We think it has to do with the small plastic filter at the back of the senseo that pushes the 'valve' of the water reservoir.
Only if we push a few times at the filter, then the blinking disappears.
A few weeks ago we applied a descaling of the unit with citric acid.
What you suggest to do?
  • 6 Answers
You are correct in thinking the problem is caused by the valve. Use a magnet to connect to the valve from the outside of the machine, slide the magnet very slowly upwards along the water level, the rapid flashing should stop and the water should begin to heat, if not try again as you have not connected the valve to the magnet
Posted on Oct 16, 2009
  • 52 Answers
1. If the Senseo blinks fast, then it is the float. If the float seems to move up and down easily then use a magnet on the left hand side where the float would be and see if it starts blinking slow and heats. If yes Then replace tank with new float. Fixed!
If not.
2. Unplug and then take the back cover off and make sure the electronic magnet sensor is in Its plastic case and fully set in place. (Bottom left) If its is out of place Snap back into place or use glue. With cover off, plug it back in. (Don't touch anything on the inside! Electrical shock!) Turn on Hold a magnet against the sensor and see if it blinks slow. If it keeps flashing fast, replace the magnet sensor. Fixed!
If not.
3. If it blinks slow and never stops blinking then check the voltage at the thermal fuse. (Right side of the holding tank) Take the back cover off then take the plastic cover off. (Don't touch anything on the inside! Electrical shock!) Turn on. If you have voltage at one side and not the other then replace it with, Thermal Fuse 206C, 120V, 15A, Type 155431. Loosen the metal band that holds it on. You may have to cut the wire from one side of the thermal fuse and crimp on a quick connect to that wire. Install new thermal fuse then reassemble. (Don't forget the plastic cover that goes over the thermal fuse.) Fixed!
If not.
4. Check the heating element with an Ohm meter. Unplug and remove back cover. If you have zero or infinite ohms, The heating element may be burned out and may not be worth fixing. Buy a new one. Fixed!
Good luck. VicFixx
Posted on Mar 06, 2013
THE RED BUTTON FLASHES RAPIDLY
I guess it's the metal part in the water tank that makes contact with the machine when the water runs out. When you take the water tank off the Senseo it's in the bottom right corner. If you can't repair it, a spare water tank isn't that expensive.
Jun 20, 2014 | Philips Senseo HD-7810 Coffee Maker
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
Hello, Hope you guys can help me on this one: My philips senseo coffee machine blinks constantly when I turn it on as if there is no water. However, there is enough water in the tank. If I hold the tank...
Either the little magnet in the reservoir is stuck (does it float when you slowly fill up the reservoir?), or the corresponding Reed relais doesn't properly respond to the magnets presence. The latter most likely requires technical attention.
Aug 22, 2010 | Philips Senseo HD-7810 Coffee Maker
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Oct 10, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo won't fill itself on initial flush
Sounds like resevoir was not seated properly or something is in the resevoir. try pushing the pin on the bottom of the resevoir, do it over the sink, and see if water comes out. if tht works then its internal to the machine. Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Oct 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo 7818
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
Jan 13, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
1,640 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
