Home | Mackie | SRM-450 System | I have Mackie srm 450...
Mackie SRM-450 System
Problem for Mackie SRM-450 System
I have Mackie srm 450 original\r\n the speaker
By sless on Sep 08, 2009
I have Mackie srm 450 original the speaker comes on for while from start then will go-off then back on intermittently
If I switch it off then back on then sometimes it returns to power.
Doesnt seem to be like previous fault where the 'soldering of the legs' on circuit board solved prob.
As that usually made 'fault sound' this has no 'fault sound' just off..on as if lead is prob but new leads tried.
Any ideas? and or quote or nearby help
I am in Newcastle on Tyne --Sunderland area
thanx
terry Slesser
Best Solution
posted on Sep 11, 2009
Helpful)
Triarcuate
Rank: Guru
Rating: 92%, 38 votes
When it goes off, try pressing gently on the speaker membrane (you'll probably need to remove the protective mesh to do that).
If the speaker comes on for an instant or so when you press the membrane, then the cause is a broken braid wire at the back of the speaker (it goes from the connection terminal on the speaker itself to the speaker cone where it is connected to the speaker coil wire and glued to the cone to keep it firmly in place).
If this turns out to be the case, the braid can be resoldered at the point where it is damaged / broken (you need good soldering skills to do it, also the braid needs to be cleaned well which is a bit tricky because of its structure, and solder won't stick to it well if it's not clean).
The solder point should be firm, but as small and short as possible because the braid needs to remain flexible at all times since it moves when the speaker is operating.
An alternative to braid resoldering is to replace the speaker, but there may be speaker repair shops around where you can get it fixed.
The problem may as well be something else, the above is just one of the things that you can check and possibly fix by yourself.
Regards
3rq8 (Triarcuate)
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" sounds feasible will look into that soon altho away for some weeks yet so cant try immediatly TS " - sless
Solution #2
posted on Sep 21, 2009
Not Rated)
aussiedingo1
Rank: Apprentice
Rating: 0%, 0 votes
Lookin backs ex roady here. Terry dose the horn go off as well? dose the main driver go off are dose it sound really low? the common faults with these is the capacitor's, either dry joints are drying out,
Have two of these here with low volume and scratchy speaker'
I've replaced the capacitor's which sorted the low volume, now got to locate a driver
Aussiedingo1@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Mackie SRM-450 System
Questions and Unsolved Problems for Mackie SRM-450 System
Do you recommend Mackie SRM-450 System?
Answer
Answer
My Mackie speakers hum as soon as they are powered on, even if the sound board is on also. When I... (More)
Answer
SRM450 when powered on makes 120hrz full volume hum/buzz.  has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mackie SRM-450 System:
Top Home Theater Spe... Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater Spe... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
